Sponsored by: CARiD
used seafoam, no smoke
Old Apr 5, 2011 | 10:23 AM
gweelie's Avatar
1995 pickup 5 speed 165k miles
Last night I used seafoam in my truck for the first time, follow instructions, no smoke. Warmed up truck, slowly put 4 oz into brake booster vac line ( took about 3 min) turned off engine and let it sit about 7 min the took off... Nothing. Do I have an amazingly clean engine or did I screw up? Anyone else have this result?
Old Apr 5, 2011 | 10:42 AM
Soobarubin's Avatar
From my experience, the only time I've ever gotten smoke from a vehicle, is when it's carbed and you pour it right down the throat, choking it so it dies. Then on startup it will smoke. Never have gotten my EFi trucks to smoke.
-Jaren
Old Apr 5, 2011 | 10:50 AM
gweelie's Avatar
I was very paranoid that my neighbors would call the fire department with the plumes of smoke everybody talks about. To be honest, I didn't really notice any difference either in performance or running condition. The only reason I did it in the first place was I had no vacuum through my egr and a smog tech suggested that it may clear out and carbon buildup stopping the vacuum.
Old Apr 5, 2011 | 11:30 AM
blake.nemitz's Avatar
mine smoked out the whole neighborhood, i added it in the correct vacuum line though
Old Apr 5, 2011 | 04:48 PM
gweelie's Avatar
From what I read on here, the brake booster vac line is the right one
Old Apr 5, 2011 | 05:20 PM
cman1's Avatar
mine smoked like a freight train!!!
Old Apr 5, 2011 | 05:38 PM
gweelie's Avatar
I also read the pcv valve is a good location, I may try that in a couple of days. I do regularly clean the throttle body, perhaps that has helped keep me clean.
Old Apr 5, 2011 | 06:02 PM
rattlewagon's Avatar
I did the break booster and smoked like cheech and chong
Old Apr 5, 2011 | 06:11 PM
gweelie's Avatar
Ha ha ha. I'm thinking my truck is just nice and clean, I'll give it another try in a couple days and see what happens.
Old Apr 6, 2011 | 09:04 PM
peow130's Avatar
Pour 1/3 in gas, 1/3 in oil
Start engine, pour the last 1/3 into the vac slowly, then when it's almost done pour it all in quickly to stall the engine out.
Wait 5-10 mins, and start it up.
If it doesn't smoke, then it didn't circulate through your engine (my best guess)
Old Apr 6, 2011 | 09:46 PM
laskt9's Avatar
i do the same but i let it sit for an hour. tons of smoke.
Old Apr 7, 2011 | 06:32 AM
The truth about seafoam thread:
https://www.yotatech.com/forums/f105...-truth-160613/
Old Apr 7, 2011 | 06:43 AM
Romans117's Avatar
It works. I have used it alot. It needs to set 15 minutes after. 165,000 should smoke like a chimney.
One thing I would add is I did a rebuild on my 89 22 re and sent my injectors to witchdoctor and they were 89% before he cleaned them. I attribute the cleanliness to monthly sea foam in a my gas tank. The motor have 220,000 on it so you know the injectors were not new.
Old Apr 7, 2011 | 07:02 AM
Team420's Avatar
Same here... No smoke, well... Not the plumes I have heard about anyway...
I too attribue this to a clean motor.. Mine had 250k when I did it, butnmost of those were highway miles, I imagine if they had been 250k in town/city miles, it prolly would have smoked like a chimney...
puddlepirate
Jul 30, 2016 06:29 PM
urabus
Nov 10, 2015 07:38 PM
dzldust
7
Oct 6, 2015 05:39 AM
charlie_fong
Sep 27, 2015 10:06 PM
Boomer8404
Sep 10, 2015 09:01 AM
