Sponsored by: CARiD
Tire information needed....
Old Jan 8, 2007 | 08:51 AM
2000t4r's Avatar
I'm in need of new tires and looking at getting another set of Revo's. I was looking on tirerack's website and had a few questions.
First question can I put 265/75/16 on stock rims and a stock height truck?
Second question tirerack list three different tire configurations
265/75RR/16 E
265/75SR/16 C
265/75SR/16
I know the RR and SR are the speed ratings but what do the E and C stand for?
Thank you for your help.
Old Jan 8, 2007 | 09:02 AM
sdstud212001's Avatar
265/75RR/16 E
265/75SR/16 C
265/75SR/16
I could be wrong but I think it's load rating
Old Jan 8, 2007 | 09:12 AM
gregbreakseverything's Avatar
load rating indeed. But I dont know what the letters mean in 'X' ply. I have 4 ply winter tires on right now, they are a little squishy for my likes. Thats probobly the 'C' rating.
bob200587's Avatar
Should be load ratings
E being the highest load rating, followed by C and so forth.
Elton's Avatar
it is the load range
Old Jan 8, 2007 | 09:14 AM
Elton's Avatar
http://www.tirerack.com/tires/tirete....jsp?techid=55
Old Jan 8, 2007 | 09:15 AM
2000t4r's Avatar
Thank you^^^^^^^^^
Ok so will 265/75/16 fit on OEM rims and a stock height truck?
Old Jan 8, 2007 | 09:32 AM
emptypockets's Avatar
Thank you^^^^^^^^^
The tires will fit just fine. There should be no rubbing issues going with that size. Depending on the exact tire, they're only about .75" taller than the stock 265/70's.
Old Jan 8, 2007 | 09:34 AM
Elton's Avatar
when i get new tires im going to that size the 70's look a little small
Old Jan 8, 2007 | 10:16 AM
04 Rocko Taco's Avatar
the stock 265/70/16's are just about 30.6 inches tall, and 10.4 inches wide, while the 265/75/16's are just around 31.6 inches and still 10.4 inches wide. They will fit fine. I run 265/75/16 Kumho Road Venture A/T's on ym 04 D cab Taco.
Old Jan 8, 2007 | 10:44 AM
Bob_98SR5's Avatar
Thank you^^^^^^^^^
2000,
you really need to use the search feature here.
moved to newbie forum
bob
Old Jan 8, 2007 | 10:47 AM
2000t4r's Avatar
Thank you Bob,
When I did use the search function the information is so confusing and different from post to post it's tough to figure out what the correct answer is.
I was just trying to get a straight answer.
Old Jan 8, 2007 | 10:52 AM
jjrgr21's Avatar
P-rate/4ply
C-6ply
D-8ply
E-10ply
i just blew a sidewall on my 10ply tires, and am running the stock p-rate, and it is very squishy, i hate it. go with the C or D rate tires. if you get the bfg a/t you lose the severe weather rating with the 10 ply(no clue why), but i assume it's still the same tire.
Old Jan 8, 2007 | 12:35 PM
4Crawler's Avatar
http://www.4crawler.com/Diesel/Tires...dIndexVsRating
djpg2000
Nov 11, 2020 04:56 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
colasurdo
Jul 18, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
