tire fitment?
Old 01-28-2010, 05:51 AM
myyota85's Avatar
tire fitment?
ive got a 85 yota i run 35 x12.5 bfgs now if i go with a 35x 14.5 will they rub?
i have 4" suspension and 3"body lift. what does everyone think???
Old 01-28-2010, 06:59 AM
4Crawler's Avatar
Measure and see:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Short of a vehicle specific forum, you can try measuring. A body lift will raise the body up and most tire fitment issues are with the front wheels, because of the steering. See if you can find the worst case suspension/steering combination and then carefully measure clearance around the current tire and allow for the larger tire. For example, assume you want to go from a 31x10.50 to a 33x12.50 tire on the same rim. The new tire will therefore be 1" wider on the inside of the wheel, 1" wider on the outside and will extend 1" farther out from the wheel. So, if you had a 1" square block and could run that around the face of the tread and sidewalls all they way around the wheel well without hitting anything, chances are that tire would fit.
In your case, check for 1" wider clearance at the edge of the tread, inside and out.
Old 01-28-2010, 07:03 AM
Fink's Avatar
Originally Posted by 4Crawler
Measure and see:
As usual, Roger beat me to it.
He is everywhere.
Do you have stock wheels?
Your avatar looks like you might have Centerline's?
Fink
Old 01-28-2010, 12:10 PM
myyota85's Avatar
i dont know what i have but they look like 15x10 i bought the truck 5 months ago
Old 03-04-2010, 10:37 AM
myyota85's Avatar
well got the new tires 35x14.5 15 rims
they rub just a little at full steer.
Attached Thumbnails tire fitment?-dsc00050.jpg   tire fitment?-dsc00049.jpg   tire fitment?-dsc00048.jpg
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
AkitaDog
09-03-2015 09:01 PM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: tire fitment?
