timing chain cover stuck
Hi all.
I am trying to remove my timing chain cover without removing the head or the oil pan. I have all the bolts out including the infamous hidden ones. Is there a trick to getting this thing off? Or do I just keep tapping on it? It is a 1990 22re.
Thanks in advance.
Deano.
Thanks in advance.
Deano.
well....1st of all....it CAN be done with the head and pan on but can cause problems down the road......crunching the head gasket and getting a poor seal at the oil pan. but it can be done.
there is (or should not be) any sealer other than a few DABS where the cover meats the head and a bead of it where the pan meets the timing cover.
are you sure you have the pipes disconnected from the rears of the cover??
if you are certain, I would just take a short length of 2x4 and hold it here and there and over there and rap it with the hammer to get it to budge.
You don't have to drop the front diff to do that timing cover. I did mine without pulling the oil pan, and it leaks more now after a full rebuild then it did when I did the timing cover.
yeah it only leaks more now because I used that stupid cork gasket w/ RTV instead of just RTV. Just be careful putting it back on and not pinching that part of the headgasket above the cover. Because once you do, it will kea till ya take the head off for a headgasket job. Don't ask how I know.
RTV (TOYOTA FIPG) on the oil pan. And RTV just in the corners where the timing cover meets the block on the top. But not on the whole thing.
And just an FYI when you go to put it back together, put the bigger bolts in first for the timing cover but leave them slightly loose to where the cover can move around a little bit and then tighten the hidden bolt on the top of the cover to spec first before tightening any of the timing cover bolts. This will allow the top to seal better.
Also some reports including myself, that the timing cover gaskets tend to be a little long and usually have to get shaved down a bit on the top and bottom where the head meets the cover. You may or may not be able to catch this with the head still on so look for it.
I think the only reason was in my case is because my block was shaved by .010" and the bottom was also shaved just a slight amount to make it flat and true.
There really isn't much cork gasket on the exposed part of the oil pan anyway. I thought about scraping it off and using fipg. As far as the head gasket that is exposed, i wasn't sure if rtv and cork would like each other. So just a dab on the four corners of the top of the cover? Thanks for your help.
Deano
Deano
There's a cork gasket on there? Looks like someone has already been in there at least once already. The later model 22r/22re's all had FIPG only and no gasket. I am surprised it wasn't leaking to begin with.
You can use the FIPG but only in the corners. It's listed in the FSM where to put it at. I would leave the cork in place unless you were removing the whole pan. Otherwise you might get even a worse seal.
