timing chain cover stuck
FSM: right click and save as, it's a big file.
not sure which one you need though.
93 Pickup http://www.ncttora.com/fsm/1993/1993.zip
90-95 4runner http://www.ncttora.com/fsm/1990-1995....1990.1995.zip
I don't know about you or the O.P. but my rock timing set came with a silicone gasket as opposed to a paper one. I think I remember using a very very thin coat of RTV on the timing cover gasket just enough to hold it in place now that I think about it.
#25
the 3rd and most recent time with the head off has yielded NO leaks whatsoever.
#30
22RE engine is a non interference motor
I didn't take head off nor oil pan. Took all bolts out, but left in holes to not get mixed up. I took a 2x4 and tapped to get it loose and it just fell out for me. My question is the bolt that's under the distributor in front of the head. It's stripped. Can I retap it and put a bigger bolt in its place as long as it's the same length and not much bigger than what the stock is? Everything in my 85 22RE engine is new but piston and rings.
Jun 1, 2021 01:51 PM
