Sponsored by: CARiD
Suspension Combo Question
Old Jan 14, 2007 | 01:21 PM
974cyl5spd's Avatar
Hey! I'm new here, and look forward to talkin with you guys!!
I have a question, I'm getting a 3" Revtek Lift and a 2" body lift put on my 97 4Runner next week. I'm wondering what I should do in the way of shocks/coils? will Tundra springs work with this setup?
Also, does anyone have a similar setup here? I'm sure someone does, if so, what are the biggest size tires I can squeeze under there? I have to get goin and buy some new tires asap.
Thanks!
Old Jan 14, 2007 | 04:01 PM
tc's Avatar
tc
Check the third gen forum. The spacers work with your existing springs and shocks in the front, so you won't need anything there. What are you doing for the rear?
You should be able to fit 33x12.50 no problem. Maybe 35's, but that's where you start hitting the limits of the IFS. Lots of people run them without problems, but some people do.
If you have the 2.7L you'll want to regear. Will probably be OK with the 3.4L
Old Jan 15, 2007 | 06:21 AM
974cyl5spd's Avatar
Yeah I have the 2.7L unfortunately! So I was planning on regearing. I was talking to the guys at National 4WD and they said it would need to be regeared for sure. I'm expecting a pretty substantial power loss.
Old Jan 15, 2007 | 10:05 AM
tacoma728's Avatar
It still will have a lot of torque but on the highway up hills you will find no power at all unless you start downshifting. I got the Revtek and a 3" body lift
Old Jan 17, 2007 | 04:37 PM
974cyl5spd's Avatar
So did you use your stock coils/shocks with the revtek lift? Also, how much alteration to the steering shaft/driveshaft etc. did you have to do with that 3" body lift? I was thinking about doing the 3" instead of the two inch, but if theres too much modification needed then I'll just do the 2".
Old Feb 10, 2007 | 11:37 AM
tacoma728's Avatar
yes, same IFS stuff, the kits come with everything you need if you get the performance accessories kit. Do the three inch, its really worth it.
Old Feb 10, 2007 | 11:49 AM
4Crawler's Avatar
Same steering adjustments for 2" or 3" body lift:
- http://www.4crawler.com/4x4/ForSale/....shtml#Updates
Driveshafts are not affected at all by a body lift.
Old Feb 10, 2007 | 01:09 PM
ROOFGOOF's Avatar
Get the front Differential Drop kit if you plan on putting those spacers on the front !
Old Feb 11, 2007 | 12:14 PM
tacoma728's Avatar
After a long time of wheeling, the revtek has held up and i would recommend it.
nvdesertrunner
May 11, 2020 08:18 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
coffey50
Jul 28, 2015 10:55 AM
Athansinis
Jul 27, 2015 08:38 AM
Vargntucson
Jul 4, 2015 12:15 PM
