starter relay
Okay, so to fix the flaw I cut the big red wire diagonal from the thin blk/w/red stripe wire, before the plug to the starter relay, tape off harness side then run 12gauge wire to a kill switch, then to a 30amp fuse( seeing that I do not have a fusible link and the part is discontinued) then to the positive post on the battery. Is that correct?
Thankyou
Thankyou
Some additional information below:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
I used a Painless Wiring Hot Shot relay kit on my '85 and it has worked just fine for the last 10 years or so. Just followed the included instructions. Only wire I had to cut to install the relay was the one to the starter solenoid, I cut that and put in a male and female spade lug there. Then I used those connecters to splice into that wire to turn on the hot shot relay and then to feed the relay output to the starter. I did it this way so that if that relay ever would act up, I can just disconnect it and connect the starter back to the factory circuit.
...I cut the big red wire diagonal from the thin blk/w/red stripe wire, before the plug to the starter relay, tape off harness side then run 12gauge wire to a kill switch, then to a 30amp fuse( seeing that I do not have a fusible link and the part is discontinued) then to the positive post on the battery. Is that correct?
Also check 4Crawler's solution if that would work for you. Best of luck.
Thanks Crawler, I am going to finish this project first, thanks Rad, I will be back at my truck in a couple and I will post pics to clarify, that I am doing it right, before I cut any wires.
#25
(1) So is this the wire to cut( the one the pliers are on)?
(2)this is my replacement for the fusible link, 6awg speaker wire, from batt to 80 amp fuse
(3)this will go inline on the bypassed wire w/ a 30 amp fuse
#27
DON'T Cut it too close to the connector, so you'll have room for changes, if necessary. Peel a few inches of tape off the wireloom and make the splice there.
#28
My reply will only apply IF and only IF you verified as suggested per post above...
Did you verify that the black wire with white stripe is connected to connector that plugs into starter solenoid?
Hard to see how you're wiring it unless you show pictures of where everything goes.
To simplify:
Follow this schematic to do it the way Toyota SHOULD HAVE done it:
Correct, but don't cut too close.
6AWG is way more than big enough. 12AWG will handle the 15AMP to energize starter solenoid.
Not to 80AMP fuse. Simply move Pin 4 of relay upstream of ST1 contact of ignition switch. That's between IGN and 40AMP fuse. This bypasses ST1 contact of ignition switch, the way Toyota SHOULD HAVE done it.
OR Batt positive - to inline fuse - to Pin4
To simplify:
#29
Maybe I am making things confusing,my truck did not have a 40 amp fusible link when I bought it and the part has been discontinued,and I saw that several senior members agreed that heavy gauge wire can be used in place of it, I will post more detailed pics of that repair. The repair on the fore front is the bypass to save unnecessary wear on my ignition switch, to clarify, yes I will cut the wire deep to give myself a couple inches of play and the wire I cut is the solid fat black wire diagonal from the thin black wire w/red stripe(right?), then I will crimp/sauter onto harness side of wire w/12gauge wire then to the 30 amp fuse then to an eye terminal then to the positive terminal on the battery. If that makes sense, if not I can post more pics.
Thanks Rad
Thanks Rad
#30
Darn P.O.'s who butcher wiring! Knowing this It is important that you verify the wiring like I mentioned but you never said if you did.
... heavy gauge wire can be used in place of it, I will post more detailed pics of that repair. The repair on the fore front is the bypass to save unnecessary wear on my ignition switch
... yes I will cut the wire deep to give myself a couple inches of play and the wire I cut is the solid fat black wire diagonal from the thin black wire w/red stripe(right?), then I will crimp/sauter onto harness side of wire w/12 gauge wire then to the 30 amp fuse then to an eye terminal then to the positive terminal on the battery. If that makes sense, if not I can post more pics. Thanks Rad
You connect the connector side (This goes to pin 4 of relay) of wire to your fused wire to battery.
Please see my complete post for more details:
https://www.yotatech.com/forums/f199...l#post51975700
The only difference would be that you will connect your Pin4 to fused wiring to battery-similar to what Alverta4X did.
You're most welcome.
#31
Knowing this It is important that you verify the wiring like I mentioned but you never said if you did, Did you verify that the black wire with white stripe is connected to connector that plugs into starter solenoid?
No, I will do that.
No Not the harness side of wire. You insulate that part and not connect to anything.
You connect the connector side (This goes to is pin 4 of relay) of wire to your fused wire to battery.
Okay, so I want to send constant power to the starter relay?
Thanks Rad
No, I will do that.
Thanks Rad
#33
Thanks Alberta, also
Yes I checked, the black wire with white stripe appears to be connected to the connector that connects to the starter, the connector is a little oily and the plastic is starting to crack, I will clean it up a bit.
Thankyou
Thankyou
#34
I finally did the repair, I still dont understand what I did, the truck seems to start better and it feels good knowing I am not frying my ignition switch, thanks for all your help guys.
I will post a photo later, its to slow now.
#36
Yeey! Glad to know it worked for you. Way to start the new year
You just did the right thing
Hawaiian hillbilly? LOL!
Aloha!
Aloha!
#37
hey guys so i was researching in google and this page popped out so i decided to become a member..im having problems with my 86 runner it wont start..it went from starting fine to not wanting to start sometimes to not starting at all..i dont know much about wiring and mechanics but ive learned a few from your posts.. anywho when i try to start the runner all i get is the starter relay and COR clicking.. i tested the wires that go to my starter relay and all read around 12 volts..ohh and also once in like 10 attempt to turn it on it will crank.. hopefully you guys can give me some advice on what to check..oh and also i dont use the key i have a pushstart button dont kno if that will have something to do with it..i got the truck like this about a month ago
#38
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Easy enough to replace:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
#39
is there a way that i could test to see if the starter solenoid is good..i took the starter a few days ago to autozone and got it tested..they said it was good but i had a guy tell me ..autozone is crap cuz the dont test it while in pressure idk what he ment
