Sponsored by: CARiD
snorkel question
Old Feb 20, 2011 | 10:52 AM
jjearl's Avatar
snorkel question
would installing a snorkel on a 3.0 have the same effect as a cold air intake?? it would make sense since it is getting its air away from the engine... or does it take away performance
Old Feb 20, 2011 | 10:56 AM
Tofer's Avatar
Sponsor
not only colder but less dust on the trail..
Old Feb 23, 2011 | 11:11 PM
Swim's Avatar
And you can sorta go through water without sucking it in.... it might leak in, but it won't suck it in.
Old Feb 24, 2011 | 11:58 AM
85TurboRunner's Avatar
As long as you're moving it will have somewhat of a cold intake effect. When I put a snorkel on my 4runner with the turbo engine it drastically reduced my intake temps. I went from not being able to touch it to it being cold to the touch.
Old Feb 24, 2011 | 12:20 PM
Junkers88's Avatar
A snorkel has a couple of benefits.
1) You get cooler air from outside as opposed to the hot air in the engine compartment.
2) If you seal the intake system you can ford deeper water although other things like the alternator still get wet and you run the risk of the fan blades catching water and flexing into the radiator.
3) It looks freaking COOL!
I just did an intake mod on mine to pull cooler air from the cowl area to reduce temps and help gain some millage but it's not really "done" yet. If you have the chance to run a snork then do it.
Old Feb 24, 2011 | 07:01 PM
Birdbrain's Avatar
And it gains like 500 HP!
Old Feb 24, 2011 | 07:21 PM
Swim's Avatar
Whoa, 500hp. I'm ordering one! With my fine sticker collection I should be up over 1000 hp!!! Roof box stickers add hp right?
Old Feb 24, 2011 | 07:22 PM
xxxtreme22r's Avatar
this is interesting, I know it will bring in cooler air, but.... will it restrict airflow more than a deckplate mod or the amount of air a carb (weber included) is capable of pulling in?
Jun 1, 2021 01:51 PM
priest16
15
Aug 6, 2015 07:43 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
