Sponsored by: CARiD
Shock Advice
Old Apr 26, 2011 | 05:34 AM
tardman91's Avatar
Shock Advice
I was wondering what shocks you guys would recommend for my 1994 4Runner 3.0 4WD automatic. I don't do much off roading. I'm mainly looking for a smoother on-road ride. The shocks on the truck look pretty beat. I'm looking to do this on the cheap. I figure order online (or pick them up locally if there's a good deal) and either install them myself or take them to a mechanic friend of mine for install. I think I can tackle them myself, but while I'm on the subject, is there a write-up with some pictures of how to do it? Thanks.
Old Apr 26, 2011 | 06:21 AM
Yotard's Avatar
If you aren't looking to lift the truck at all, just get a high end monroe or something along those lines. Changing the shocks is very simple. The rear springs have a tendency to sag, especially as old as it is. I would recommend replacing the springs in the back. If you don't want to lift it at all you can go with a stock replacement. Old man emu makes a good high quality spring in different ride configurations from stock to heavy duty. They also make great replacement shocks especially if you want a 2" lift. Even though this is more designed for lifting, there is a lot of good suspension information here: https://www.yotatech.com/forums/f116...-guide-155339/
Old Apr 26, 2011 | 06:44 AM
tardman91's Avatar
Thanks. I'm not really interested in lifting it at all. Been there done that with my old truck. Maybe once this isn't my daily driver I'll turn it into a real trail rig, but for now I'm sticking with stock. I'll replace the rear springs with some OE replacements in the future (I think new shocks will help a lot for now), but the wife, or $$$, won't allow for it right now. I think I can scrape together $100 or so for shocks though, especially if I do it myself. I would have to pay someone to do the springs. I'm not messing with those.
Old Apr 26, 2011 | 09:57 AM
Yotard's Avatar
You probably won't get anything decent for less than 200 just to warn you...you may as well just do 2 now and two later. Rancho's are a decent cheap shock at 50 bucks a piece.
Old Apr 26, 2011 | 10:07 AM
SCToy's Avatar
I love my bilsteins on my stock suspension 95 pickup. I believe I paid about 60 dollars a corner. I just did them 2 at a time because money was tight. I cannot tell you how much better they ride than my other truck on ranchos. I will be throwing the ranchos away when I upgrade the suspension, I couldn't wish such a terrible ride on someone else even if they wanted them.
Old Apr 26, 2011 | 10:25 AM
Nervo19's Avatar
Based on my extensive reading and searching on a couple of forums including this one Bilsteins are the best for what you want. They cost more than I wanted to spend though. Ranchos seem to rust. If you are in CA or AZ that might not be a problem. I got Gabriel Max Control for about $36 each. On my '89. My avatar 4Runner is still wearing stock at 143k.
Old Apr 26, 2011 | 02:20 PM
Adk_Yota's Avatar
just recently did some shock research and a lot of people raved about the Monroe Sensa-tracs might be a good option if you don't plan on installing a lift... maybe look into the Pro Comp ES3000s also
Old Apr 26, 2011 | 04:52 PM
tardman91's Avatar
I was looking at the Pro Comps on 4wheel parts website this afternoon. $139 for 4 of the 3000s and $109 for 4 of the 1000s.
Anybody know what they charge for install on 4 shocks? They have a 25% off coupon for installation when you buy online and pick up in store.
Old Apr 29, 2011 | 09:38 AM
tardman91's Avatar
Anyone have any experience with either the Pro Comp ES1000s or 3000s? They're only $109/$139 for a set of 4.
Also... where would be the best (read cheapest) place to get a set of factory-spec rear springs?
wberry85
Apr 6, 2018 08:45 AM
choppe777
May 16, 2016 08:00 AM
fabing455
Sep 7, 2015 08:08 AM
DiggnDeep
Sep 3, 2015 02:45 PM
Ryall
Sep 2, 2015 06:48 AM
