Sponsored by: CARiD
Sensor on 91 rear diff
Old Mar 31, 2010 | 06:56 AM
87toyy's Avatar
I'm in the process of swapping my cab and box onto another frame and running gear. When i was cleaning up the frame i noticed a sensor on the top of the rear diff.Anyone know what it is for? I've got 3 other rear diffs here and they dont have it.
Old Mar 31, 2010 | 04:28 PM
myyota's Avatar
It might be for anti lock brakes ? (thats just a guess).
Old Mar 31, 2010 | 04:36 PM
runneroffroad's Avatar
ya its the abs senser. if u dont want it just pulg the hole
Old Apr 1, 2010 | 04:45 AM
87toyy's Avatar
I kinda figured that is what it is. I'm putting a cab on the truck thats just a base model. Will there be a spot to plug the abs into?or if i want to keep it will i have to change the wiring too?
Old Apr 1, 2010 | 06:07 AM
peapicker's Avatar
Depends on the year and not the model. 91 and older did not use the abs sensor. 92 and newer does.
Old Apr 1, 2010 | 06:34 AM
87toyy's Avatar
The one with the sensor is a 1991 and has the abs. And the one with out that i'm using the cab with is a 1990
Old Apr 1, 2010 | 07:08 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
yeah, this stuff is a no brainer... What else would there be a sensor on a diff for?
I'd drop the diff into or out of what cab you use... B/c it will be wired for it. It'll throw a code if you just bypass it... And rigging it to work won't be as easy as just replacing the diff and retaining ABS anyway....
You can block one off two ways... One is just cut the wire and leave the sensor in it, and Inchworm sells a freeze plug for it...
Old Apr 1, 2010 | 07:29 AM
87toyy's Avatar
Well i kinda figured thats what it was,but wanted to make sure of it. Is this not the beginners forum? I'm not gonna be switching the diffs because the other has holes in it and leaks fluid.If i can just cut the wires or plug the hole then thats what i will do.
sandyota
Feb 4, 2021 11:16 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
88yodabasket
Jul 13, 2015 01:32 PM
wilbertd
Jul 6, 2015 07:39 AM
