Sponsored by: CARiD
Rusted Axle Housing
Old Oct 9, 2013 | 12:16 PM
sjsphoto's Avatar
Rusted Axle Housing
2002 Tundra 4x4 V8. Dealer took care of frame rot recall by coating the frame but since then the rear axle housing rusted through and all fluid leaked out. Mechanic can't weld it. Can't find a used cheap enough. Any recommendations besides ordering a new $800 casing and swapping all of the guts?
Thanks in advance for any help.
Old Oct 9, 2013 | 01:50 PM
wyoming9's Avatar
Red face
Find someone that can weld!!
I am not sure of the Tundra but I had figured out on the Tacoma a standard pipe cap could be welded on.
I can`t remember the size.
I would just need to weld in a fill plug.
Old Oct 9, 2013 | 02:15 PM
Stetson_md's Avatar
Maybe swap in a used non yota rear end?
Old Oct 10, 2013 | 12:44 PM
sjsphoto's Avatar
Thanks, I will look into both of those Ideas.
Old Oct 10, 2013 | 01:53 PM
CJM's Avatar
CJM
T100 uses same rear axle, although gears will be different.
Old Oct 10, 2013 | 02:06 PM
Teuf's Avatar
Show a picture, then we can see if its weldable.
Old Oct 12, 2013 | 07:05 AM
wyoming9's Avatar
Red face
It can always be welded weather till it is done it is cost effective is another thing.
Old Nov 23, 2013 | 08:52 PM
p10leadman's Avatar
I am the guy with the 02 tundra 5 years ago, with the rusted welded on cover.When I originally discovered the leak, I drain it, washed the exterior,then sandbladted the exterior,then applied 3 layers of JB WELD. There is nothing to weld to, as this cover plate is very thin, and corroded..2 years later the JB WELD has given out. IT is time to replave the entire AXLE HOUSING. anything under $1,900.oo is reasonable [ fiigure 3 loan payments ]
Old Nov 23, 2013 | 11:02 PM
Teuf's Avatar
I guess there is no picture.
Old Nov 24, 2013 | 09:10 AM
wyoming9's Avatar
Red face
Well one would need to replace the whole back of the rear I am trying to get my hands on a rusted housing .
To show how easy it is to fix this problem.
If shipping would not be so expensive I could do them on a exchange basis
Like anything else to do this correct you need to pull the housing out of the truck .
coreyedwards7611
Jan 16, 2016 06:38 PM
deepmarsh
Aug 6, 2015 03:44 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Edionne13
Jul 9, 2015 01:59 PM
