Sponsored by: CARiD
rough idle when motor is warm
Old Nov 17, 2007 | 09:59 AM
livinkush's Avatar
im kinda curios if anybody has had this problem.i have a 89 yota pickup with 22re auto trans,when i start it when its cold it fine and then when its warm at like lets a stop light its fine but as soon as i turn it off and turn it on it shakes till its turns it self off,it well stop as soon as i get the rpms past 3000 continously. i already changed the battery and main cable to the main fuse box if anybody has any idea what it could be please let me know, thank you
Old Nov 19, 2007 | 06:08 PM
colsoncj's Avatar
Is you check engine light working (i.e. on when key on and not running) and is it on when your driving?
Old Nov 19, 2007 | 10:14 PM
1/2 cab's Avatar
TUNE-UP AND CHECK YOUR VALVE LASH
Old Nov 28, 2007 | 09:55 AM
livinkush's Avatar
hey thanks for the replys, my engine light does not turn on when im driving,
Old Nov 28, 2007 | 10:12 AM
colsoncj's Avatar
does it smell like its running rich? possibility the cold start injector is sticking on dumping more fuel in and the truck cant burn it at idle. Not sure how much it compensates though.
Old Nov 28, 2007 | 10:49 AM
jagger_snitt's Avatar
It sounds like a Valve setting or Timing issue. If it is starting ok it sounds like there isn't a fuel delivery issue unless your fuel pump is intermitantly going out,or you have a semi clogged fuel filter,It sound like your valves are out of adjustment allowing the engine to run fine until it warms up. The timing could also be off. Hope this helps you narrow it down.
Old Nov 28, 2007 | 11:08 AM
4Crawler's Avatar
Might want to check out the EGR valve and modulator. When it is idling rough, tap on the EGR valve body and see if that smooths out the idle. The EGR valve may be sticking slightly open.
Old Dec 3, 2007 | 04:07 PM
livinkush's Avatar
thank you guys for all your suggestions im gonna try a couple of those suggetions ans see what happens.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
ty1er
Jul 19, 2015 06:42 PM
