Ripped CV boot
Ripped CV boot
Just got out of the garage from putting in an ome steering stabilizer (its awesome). While under there i noticed the left cv boot closest to the differential is ripped. there is also alot of grease around where it ripped. i kinda have a metal on metal sound when driving. This is with my hubs disconnected. What happened? how do i fix it? thanks
CV boots fail. The rubber boots can only take so much. I just bought a 98 Subaru Forester. I crawled under the car before I bought it and saw the front left inner boot was torn. I got an extra $200 price adjustment for that. My Subaru mechanic buddy recommended just replacing the whole cv axle assembly. That's commonly recommended here on YT as well. The replacement axle assembly from Autozone with a lifetime warranty costs about $70. The installation isn't too difficult either.
Did I do something to cause this. I have 116k miles on it. and i believe those are the originals. What is the metal on metal i hear when im driving though. Could the grease be coming out of my bearings and that is what i hear?
Have you opened the tear up and had a look inside yet? Is the truck clicking when turning? Like what was said before, if the boot is torn, it's probaby just best to replace the axle itself as well, because the work is almost the same. plus if the tear has been there a while it most likely has thrown all the grease out and your hearing the metal on metal sound of the joints rubbing together and you're probably about to pop the CV shaft anyhow.
Just a quick question, aboutl lifetime warranty...We do not have Autozone in Hawaii, the best that I've found around here was Napa Auto (double the price of Autozone)...Lifetime on the CV shafts and components, except the boots. . Does Autozone warranty cover boots too?
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
