Sponsored by: CARiD
Removing Welded Sliders - Looking for Best Approach
Old Apr 9, 2010 | 02:03 PM
DOK's Avatar
DOK
I've searched and came up nothing...
I have welded sliders on my rig and wanting to remove them so I can relocate.
I am seeking advice how to best remove the weld. They are welded on a scab plate with 1 rectangular gussett. I was thinking I can use a SAWZALL to cut the pipe close to the plate. But this will leave the plate and a bit of the pipe. However, I was wondering if I can cut the WELDS around the plate using DREMEL but I am afraid that I might cut into the frame.
Any advice on the best approach to this task? Much appreciated.......
2000 4runner limited
Old Apr 9, 2010 | 02:09 PM
liquidtouch's Avatar
a plasma cutter, or torch if you are very good. also a angle grinder with a cutting wheel would do the trick
Old Apr 9, 2010 | 03:17 PM
CYi5's Avatar
If you were in socal i could plasma them off for you. Even plasma would be sketchy, it cuts so easily it'd be easy to slip into your frame. Maybe grind as much of the weld off around the scab plate as possible. I think you'll go through dremel disks wayy to fast.
Old Apr 9, 2010 | 03:30 PM
84YotaBuck's Avatar
Carbon Arc, but I would probably just cut the pipe as close to the plate as possible and leave the weld, too much risk to the frame.
Old Apr 9, 2010 | 03:51 PM
CYi5's Avatar
Ditto..gonna be fun when your sawzall nails your cab though .
Old Apr 9, 2010 | 03:56 PM
overdrive00's Avatar
zip grind the welds maybe one of your better options.
Old Apr 9, 2010 | 08:28 PM
olharleyman's Avatar
If you have them mounted to a frame plate cut the tube there with a sawzall and leave the frame mount on the frame , get a new set of plates if you are going to reuse the sliders and reweld them to the plates and then it is like starting with a new set
Old Apr 9, 2010 | 08:57 PM
yotaman85's Avatar
what he said..
Old Apr 10, 2010 | 06:14 AM
DOK's Avatar
DOK
Thanks Everyone.... At least this gives me some ideas....I'll let you all know what I do... Hoping for a clean and successful endevour....
Old Apr 10, 2010 | 10:42 AM
SoCal4Running's Avatar
It would be best to leave the plates. Remove the sliders as close the to plate as possible and then grind whats left off to make the plate smooth.
Old Apr 10, 2010 | 11:15 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Plasma = Cold cut...
Not that losing THAT much temper will hurt the frame, but it'll leave more temper in the frame than any other method of cutting them off will...
A friend of mine had some shop fly at 4Wheel parts here in Nashville put some generic ones on, and the moron welded them to the lower control arm mount of a 80 series Landcruiser. It has to come off b/c the exhaust pipe hits it and crushed it...
Using plasma will not weaken the mount anymore, or damage the bushing any more than it already is.
PETDOC
Aug 18, 2015 05:29 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
priest16
15
Aug 6, 2015 07:43 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
crashburnoveride
Jul 10, 2015 06:39 AM
