Sponsored by: CARiD
Rebuilding 3.0 top end
Old Sep 1, 2011 | 08:22 AM
cansqueezer's Avatar
Valve went bad now I am replacing heads. Any other parts that should be replaced as l have it torn down that far other than gaskets?
Old Sep 1, 2011 | 10:53 AM
Steveh29's Avatar
Knock sensor for sure. It'll go bad exactly 5 minutes after you're done with the head job if you don't.
Old Sep 1, 2011 | 11:09 AM
BMcEL's Avatar
x2 on knock sensor/wiring.
Old Sep 1, 2011 | 12:59 PM
Thanks, that seems to be the one that is the biggest pain in the assto replace
Old Sep 1, 2011 | 01:10 PM
Is it possible to just pull the sensor and clean it then put it back. And if so what can I clean it with.? Doesnt seem like a part that would wear out.
Old Sep 1, 2011 | 08:52 PM
Steveh29's Avatar
I believe the internals go bad and the resistance changes on the sensor and you're hosed - similar to how a coolant temp sensor will go bad. For the ultra huge hassle of having to change it when the engine is all buttoned up it's probably better to replace.
Old Sep 9, 2011 | 09:05 PM
okay, so after a few headaches i have the truck back together. i replaced the left head, both head gaskets, along with exhaust intake plenum and a few other seals and gaskets. it runs a little bit better but is still way under powered. it seems to run a little on the hot side. the temp guage ranges from yhe middle to almost the "h" . it can barely get up to 55. what else do i do?
Old Sep 9, 2011 | 10:12 PM
BMcEL's Avatar
High temps could be a number of things...have you checked for codes since the reassembly?
Old Sep 10, 2011 | 02:54 AM
dropzone's Avatar
Fossilized
what else do i do?
replace w/3.4
Old Sep 10, 2011 | 03:25 AM
skypilot's Avatar
If you find out let me know. Mine has less torque than a 22re. New water temp sensor (broken off) and o2, 4.30 gear; and now on to the next issue. Oh and I get 13/14mpg.
I am definately going to a 4banger when this one blows.
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
jerusry
Oct 19, 2015 05:28 PM
Coreyr384
Jul 10, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
