Rear Wiper replacement? 2002 4RUNNER
I'm trying to replace the rear window wiper on my 04 4runner.
Is it just the blade that slides out? or does something unclip?
Its been a while and i did not want to force the blade and break anything.
you unscrew those 2 small Phillips head screws where the arm meets the blade. Use the correct size of bit or you will strip them out easy.
You can then cut a wiper insert to fit-or simply replace the blade with wiper.
cchinny
Jun 25, 2015 08:11 PM
Beavah
9
Nov 12, 2013 07:31 PM
