Sponsored by: CARiD
Rear third, replace seals?
Old Oct 30, 2007 | 06:00 AM
crolison's Avatar
Hello,
I am going to be putting in a locker in a few weeks, me and my friend will be pulling the third and taking it to be professional set up. I was wondering do we need to replace the axle seals after we pull out the axles a bit? If so which seals would we need to replace the inner or the outer?
Thanks,
Chris
Old Oct 30, 2007 | 06:49 AM
GSGALLANT's Avatar
Inner seals are what you should be concerned with the most. They are cheap and easy to replace once the axles are out, so I would replace them (If you decide not to replace them, don't let the axles rest on the seals that are currently installed when you pull the axles out a bit. This will deform the seal. Pull the axles out completely until the third is re-installed).
Take a look at the outer seals to ensure they look good (what you can see of them, anyways.) You would have to press off the bearings to replace the outers, and the critical ones are the inners to keep the diff fluid from leaking out.
Old Oct 30, 2007 | 11:35 AM
tc's Avatar
tc
x2 and learned the hard way
Old Oct 31, 2007 | 05:39 AM
crolison's Avatar
thanks guys. i am going to order some inner seals from the stealership and pick them up on the way out of town.
voiddweller
19
May 2, 2016 09:10 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
cchinny
Jun 25, 2015 08:11 PM
