Question on lift for IFS pickup
Old 06-19-2006, 08:50 PM
MikeKaduce's Avatar
I have an 88 Toyota Xtra Cab and wanted to do something cooler than a body lift. What would be a cheap way to lift it otherwise?
I've heard of lifts for IFS trucks consisting of longer rear shackles and ball joint spacers, and I'm also considering the classic 63" chevy rear leaf swap. I can't afford a nice suspension lift kit, and I want my truck to sit healthy with 32x11.50 tires and flex decent too.
Old 06-19-2006, 09:32 PM
photoleif's Avatar
my understanding is you would clear 32x11.50s without any mods, or with very minor trimming in odd circumstances. there are numerous "can it fit" threads that you may find helpful. hit the search button and see what you can find.
Old 06-20-2006, 05:19 AM
tc
tc's Avatar
check out www.4crawler.com for how much lift to fit what tire size on your truck.
Roger is the man when it comes to first gen 'runners...
Old 06-21-2006, 08:07 PM
Sonofmayhem's Avatar
I think your pretty set w/ the spacers and 63s you can even buy a kit from roadless gear.
Old 06-24-2006, 03:43 PM
MikeKaduce's Avatar
I'm not concerned with fitting the biggest possible tires, I just want a lift that isn't too insane that will make my truck sit nicely (not too tall or short) with the tires (32) I have on it now.
Old 06-24-2006, 07:54 PM
tc
tc's Avatar
'88 should fit 32's just fine with no lift.
Old 06-29-2006, 09:49 PM
Christyle's Avatar
i have a friend running 33" mtrs on a stock 1st gen, he hits his idler arm on full stuff locked steering wheel. looks good like that in my opinion
Old 06-29-2006, 09:54 PM
bob200587's Avatar
I second BJ spacers and 63chevies for you. That would be ideal. you could proabably go up to 33x10.50s if you wanted with that. Plenty of clearance for the tires to stuff, and a good look, Not to mention, cheap.
Old 06-30-2006, 05:27 PM
BeaterToyota's Avatar
Yep. I ran 32x10.50 Swampers, which are almost the same as a BFG 33x10.50. I had BJ spacers and a lift shackle. If you go this route, make sure to get longer shocks front and rear or you won't get any better flex than what you already have.
GreenLion
06-07-2021 10:49 AM
Regency
20
01-03-2020 07:43 PM
6th Gear
19
12-10-2019 07:31 AM
Lowviz
07-22-2002 10:52 PM
Quick Reply: Question on lift for IFS pickup
