Question on lift for IFS pickup
I have an 88 Toyota Xtra Cab and wanted to do something cooler than a body lift. What would be a cheap way to lift it otherwise?
I've heard of lifts for IFS trucks consisting of longer rear shackles and ball joint spacers, and I'm also considering the classic 63" chevy rear leaf swap. I can't afford a nice suspension lift kit, and I want my truck to sit healthy with 32x11.50 tires and flex decent too.
my understanding is you would clear 32x11.50s without any mods, or with very minor trimming in odd circumstances. there are numerous "can it fit" threads that you may find helpful. hit the search button and see what you can find.
check out www.4crawler.com for how much lift to fit what tire size on your truck.
Roger is the man when it comes to first gen 'runners...
I second BJ spacers and 63chevies for you. That would be ideal. you could proabably go up to 33x10.50s if you wanted with that. Plenty of clearance for the tires to stuff, and a good look, Not to mention, cheap.
Yep. I ran 32x10.50 Swampers, which are almost the same as a BFG 33x10.50. I had BJ spacers and a lift shackle. If you go this route, make sure to get longer shocks front and rear or you won't get any better flex than what you already have.
GreenLion
Jun 7, 2021 10:49 AM
Regency
20
Jan 3, 2020 07:43 PM
6th Gear
19
Dec 10, 2019 07:31 AM
