Sponsored by: CARiD
Question!! Largest Tire Size for Stock Rims (16")
Old Jan 30, 2008 | 08:48 PM
2000Runner's Avatar
without any type of modification on the 3rd gen 4runner
Old Jan 30, 2008 | 08:50 PM
Skrillah's Avatar
Please, please search...this has been beaten to death!
The largest tire on a stock, 4wd, 3rd gen is a 265/75/16
Old Jan 30, 2008 | 09:41 PM
Godzilla's Avatar
Man, edit your post and take out the answer, because they just wont search then, and more similiar threads will follow!
Old Jan 30, 2008 | 10:16 PM
d0ubledown's Avatar
325/85/16 michelin XML's. do it. it'll be sick.
Old Jan 30, 2008 | 10:37 PM
stormin94's Avatar
I'd try to find a smaller tire, like a 315/65 because with too large of tires, you may have to increase your drive shaft diameter. Also, your 4Runner may suffer from incrased backpressure in the exhaust, because larger tires generate more heat that is not allowed to dissipate in the exhaust system as efficiently as with smaller, cooler running tires. you may have head gasket issues after that, and maybe would want to consider adjusting your cruise control. You can do so by using a small flat head screw driver, and turning the adjustable cruise control relay clockwise. Failure to do so could lead to catastrophic failure of the entire cruise control system, which in turn has a domino effect on many other important components in the car, such as the anti lock brakes, the fuel delivery system, and the speed and RPM read out on the guages. But if you drill a small hole in the top of your throttle body, you can avoid making any other alterations. I hope this helps.
Old Jan 30, 2008 | 10:48 PM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
^^^ Thank you for FINALLY clearing up that elusive "largest tire" question. A little involved if you ask me. I'll just stick with my 265-75s until I work up the gumption for that hole in the throttle body mod.
I say just do some and stuff 35s under there! gearing!? forget it. speedo adjustment? who uses those anymore!?
Old Jan 30, 2008 | 10:55 PM
stormin94's Avatar
I said cruise control adjustment. Those damn adjustable relays......
Old Jan 30, 2008 | 11:09 PM
nix4x4's Avatar
But the DRL disable and a SAS should clear up some of the exhaust issues because they make less heat than having extra lights plus the cv joints in the IFS setup always run hot
Old Jan 30, 2008 | 11:16 PM
stormin94's Avatar
Yes, but if you upgrade your U joint bolts to the TRD replacement ones, you are sure to combat much of the extra strain that the larger tires cause. The TRD u joint bolts will not back out as easy as stock.
Old Jan 30, 2008 | 11:21 PM
nix4x4's Avatar
Oh yeah, almost forgot to tell you that the TRD upgraded shocks are a good idea to get you like 3 or 4 more inches of lift to run insane big tires
Old Jan 31, 2008 | 12:19 AM
b.miller123's Avatar
get some 195/70/14's I just put some on my wife's 2000 cavalier, and that thing does way better off road now
Old Feb 27, 2008 | 03:09 PM
94fuelie's Avatar
Question
What does the small hole in the throttle body do for you?
Old Feb 27, 2008 | 11:30 PM
stormin94's Avatar
Nothing, DO NOT DO IT. That was an obnoxiously horribly incorrect post because this topic has been covered several hundred times over. I appologize for the crude post, the size is likely a 285-75 or so.
Old Feb 27, 2008 | 11:46 PM
I hope, for his sake, that he checked back here before he went drilling into his t/b
Old Feb 28, 2008 | 12:37 AM
notanymore's Avatar
it will make your truck run like crap and let dirt past the air filter and kill your truck faster than a ford.
Old Feb 28, 2008 | 12:56 AM
there has been an epidemic of ford's killing toyota's lately too, don't be the next victim
Old Feb 28, 2008 | 01:01 AM
stormin94's Avatar
There was a Ford broken down in the road today on my way to work....the poor thing couldn't even make it on to the shoulder. Ford owners should have to pay a special public nuissance tax when they buy a new vehicle.......
Old Feb 28, 2008 | 05:26 AM
Brenjen's Avatar
See what you could do to someone with that nonsense! Just refrain from posting if you feel the topic has been beaten to death, another person may hit on this thread while using the "highly regarded" search function & @*&% up big time. That crap pisses me off to no end, just don't reply...simple. You're going to cause some simpleton a ton of misery one day doing this & your karma is going to come back to haunt you on the trail!
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
XtraCab
Apr 12, 2020 05:25 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
