Sponsored by: CARiD
Popping coming from the front end
Old Sep 7, 2008 | 06:16 PM
hmmwv15's Avatar
I just took them off yesterday to make sure my wheel bearings were tight (which they were loose, so I tightened them, and the noise still continues) and the hubs are functioning properly so they should definitely be unlocked.
Old Sep 10, 2008 | 04:05 PM
hmmwv15's Avatar
This is driving me crazy....
Old Sep 10, 2008 | 04:20 PM
4Crawler's Avatar
With the front tires in the air, grab the tire at 6 and 12 o'clock and see if you can feel any play as you push/pull on the tire. Then repeat at 3 and 9 o'clock and see if there is any play. If felt vertically, then it is likely the knuckle bearings. If horizontally, then there may be something loose in the steering; tie rod ends, or the ball/socket joints on the drag link.
Old Sep 10, 2008 | 05:30 PM
hmmwv15's Avatar
Thank you. 4Crawler to the rescue once again.
Old Sep 11, 2008 | 02:46 PM
  #25
hmmwv15's Avatar
Definitely some vertical play, so would it be a good idea to dismantle and check them out, or could I just snug them up and get away with it that way?
Old Sep 11, 2008 | 02:58 PM
  #26
4Crawler's Avatar
Unless the steering arm and the bottom caps are loose, tightening the nuts on them will do nothing to make the bearings tighter. Bearing pre-load is set by the shims under the arms/caps:
- http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Sep 11, 2008 | 03:53 PM
  #27
hmmwv15's Avatar
Okay, I'll take this as a calling to rebuild the axle. I guess I need to load up all my scrap metal for some cash! Thanks, Sean
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
lledwod
Aug 30, 2016 01:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
