Popping coming from the front end
I just took them off yesterday to make sure my wheel bearings were tight (which they were loose, so I tightened them, and the noise still continues) and the hubs are functioning properly so they should definitely be unlocked.
With the front tires in the air, grab the tire at 6 and 12 o'clock and see if you can feel any play as you push/pull on the tire. Then repeat at 3 and 9 o'clock and see if there is any play. If felt vertically, then it is likely the knuckle bearings. If horizontally, then there may be something loose in the steering; tie rod ends, or the ball/socket joints on the drag link.
#26
Unless the steering arm and the bottom caps are loose, tightening the nuts on them will do nothing to make the bearings tighter. Bearing pre-load is set by the shims under the arms/caps:
- http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
