Sponsored by: CARiD
The OFFICIAL IFS "What size tire will fit" thread
Old Oct 4, 2009 | 11:08 AM
  #141
annoyingrob's Avatar
My Toyo ATs were fine in the snow, but my X-Ices were definitely a lot better. For $350, I would just go with the winters.
Old Oct 4, 2009 | 11:34 AM
  #142
85yota4x4's Avatar
which tire size??
im getting new wheels and tires soon, and i have a 15x7 rim right now on 30x9.5x15 and they are extremely skinny, i want a wider tire, but my main question is should i get a 15x8 or 15x10 wheel?
Old Oct 4, 2009 | 11:40 AM
  #143
OltorfTD's Avatar
tire size question
I'm planning on replacing the tires and rims on my 94 4wd pickup truck. right now it's got 235/75R15 wheels and tires. the current wheels are pretty rusty and ugly and i found some 16x8 wheels on tirerack.com that are cheap and lightweight. they're the ultra 164:
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
I'm also planning on a 3.4L swap with the supercharger eventually, and i know you need about a 1" or 2" body lift. So, my question is, what are the biggest tires I can put on it that will fit and won't need additional suspension work after the body lift? I don't want monster truck tires, just a bigger than the stock tires. right now i have rough country nitro 8000 shocks on it. Also, any other suggestions are welcome.
If it helps, my goal with the truck is for a mostly off-road truck, but not some super hardcore vehicle that sucks to take on the highway. my wife still needs to take it to work every day. it's mostly for us to take camping and stuff.
Old Oct 4, 2009 | 02:28 PM
  #144
90-3vzeslug's Avatar
31 10.5s fit easily. anything above that I'm not sure without a lift
Old Oct 4, 2009 | 02:30 PM
  #145
yoterr's Avatar
x2 ^^^
Old Oct 4, 2009 | 03:16 PM
  #146
OltorfTD's Avatar
how about with a 2" body lift?
Old Oct 4, 2009 | 03:43 PM
  #147
yoterr's Avatar
well they say with a 4" bracket lift a 33" tire is recommended so i dunno about going any bigger than a 31/32
Old Oct 4, 2009 | 03:44 PM
  #148
OltorfTD's Avatar
i'll look into doing a 32" tire. thanks for the help.
Old Oct 4, 2009 | 08:03 PM
  #149
Mrbikerman's Avatar
Tire size question
Need new tires soon, 97 limited runner, have a 3" toytec lift on front with l/c coils in the rear, a 2" body lift on the way, stock control arms, and 1" wheel spacers. What is the max tire size I can fit w/o rubbing?
Also, had a set of bfg a/t's and they didn't work too well for me. Tread was not aggressive enough for my area (Colorado dry rocks) and they didn't last long enough. Any suggestions on tires that will last longer that also have a more spaced out tread pattern? Thanks everyone.
Old Oct 4, 2009 | 08:12 PM
  #150
Mrbikerman's Avatar
One more thing, I have no idea how the wheel sizes work, what size are the stock rims? I was thinking that I need to get rid of the spacers, what's the size I need? Thanks again
Old Oct 4, 2009 | 08:31 PM
  #151
Mrbikerman's Avatar
I'm sorry this is the wrong forum. I thought I was in tires!
Old Oct 4, 2009 | 08:56 PM
  #152
BajaRunner's Avatar
3" suspension lift and a 2" body lift you'll be probably able to run 285/75/R16 (33x11.50x16) tires no problem.
Old Oct 4, 2009 | 11:25 PM
  #153
Mrbikerman's Avatar
Is that all? I was hoping 295's at least with the spacers and bl. How much trimming would be necessary, and is it mostly the front fender or both?
Old Oct 4, 2009 | 11:30 PM
  #154
Mrbikerman's Avatar
Hi, I have a 97 Limited runner with 3" toytec coilovers in front, fj80 coils in the rear, a 2" body lift on the way, and 1" wheel spacers. Stock control arms. What is the largest size tire I can run with little to no rub?
Also can someone recommend a longer lasting, more aggressive tire than bfg a/t's? I need a much better tire for wheeling, and noise is not an issue.
Old Oct 5, 2009 | 02:19 AM
  #155
rocket's Avatar
Wow since 04' you never bothered to search the most asked question of all time??
https://www.yotatech.com/forums/f120...l-watch-73590/
Old Oct 6, 2009 | 04:54 PM
  #156
Stuwy123's Avatar
BFG All Terrain T/A KO
33x12.5R15 require a minimum of 8.5" wide rims.
Recommended rim width: 8.5 - 11.
Same thing for the 35x12.5R15.
Old Oct 8, 2009 | 07:49 PM
  #157
yoterlve's Avatar
Biggest tire size on 97 tacoma
I need to buy new tires for my truck soon. Wondering whats the biggest I could go on stock lift and stock rims (15 inch i think?) WITHOUT RUBBING ON FENDERS?
GREATLY APPRICIATED IF YA COULD THROW IN SOME PICTURES TOO!
Old Oct 8, 2009 | 08:37 PM
  #158
BajaRunner's Avatar
31's???
Old Oct 8, 2009 | 09:20 PM
  #159
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Use the Search button in the top right, should get you some answers
Old Oct 8, 2009 | 10:25 PM
  #160
dropzone's Avatar
Fossilized
try this thread;
http://ttora.com/forum/showthread.php?t=80999
