Sponsored by: CARiD
The OFFICIAL IFS "What size tire will fit" thread
Old Mar 17, 2012 | 05:20 PM
  #401
MalachiRunner's Avatar
Like some of the other guys said...get the right backspacing on your wheels and you wont have any rub issues...besides it looks cool when the tires stick out man!
Old Mar 17, 2012 | 10:05 PM
  #402
Red Wagon's Avatar
The stick out pretty far already.
Thanks for the replies fellas.
Badfish, 33's are great and I would probably stay with that size if I didn't have to regear and need replacement tires at the same time. Bits of ring teeth fell out of my drain plug when I went to eliminate my ADD system. My tires are also getting pretty bald so figured why not go a bit bigger to help out in the muskeet bogs which are almost bottomless way up here. I really don't like getting stuck in them, they literally make the inside of the truck stink like manure for the entire wheeling season and for 6 weeks after your last trip before everything freezes again.
Next project that will happen along with body work is carpet removal.
EDIT//
I'll also be getting new plastic for my steering stops. The metal has punched through the old plastic and you can feel a recess where it's been grinding to make that sound. Thanks again Badfish.
I went down to look under the front after I wrote the above. My skid plate is still off from my ADD elimination attempt. I saw that damage and took a look at my steering stabilizer which is definitely stock.
Thanks again.
So besides a beefier steering stabilizer and new plastic caps anything else up front I might want to do for the IFS on 35's?
Old May 2, 2012 | 01:47 AM
  #403
Salt George's Avatar
1997 Hilux 4Runner
I own a 1997 4Runner. Most often the brakes work very fine but some times when I press on the brake pedal it behaves as if it is pushing back against my foot.
I had the brakes system checked, the back Brake shoes were replaced together with the front disc. My mechanic told me there is nothing wrong with the ABS system, yet I keep having this reaction once in a while. Is this a normal reaction?
Old May 22, 2012 | 01:36 PM
  #404
Bdavis's Avatar
I have a 1994 toyota extended cab 4x4 with a 2.5 inch lift and i was wondering if i could fit 33s?????
Old May 22, 2012 | 06:34 PM
  #405
Red Wagon's Avatar
Yes. If they rub get new rims or wheel spacers.
You will lose power without regearing to 4.88 ratio though. I had 33's on stock gears in my differentials and it was sluggish. I have 35's now and geared to 5.29's at the same time and I have more go power than I had before.
Old May 24, 2012 | 07:17 PM
  #406
Bdavis's Avatar
alright man, i appreciate the insight
Old May 28, 2012 | 04:36 PM
  #407
sethman42's Avatar
What type of tires
I have a 97 4runner i just bought, and i know i can run a 31 inch tire on my stock suspension. i just dont know what kind i want. i wana be able to run some sort of all terain, with super agresive features. and i want good life out of them, and i dont have a lot to spend. hoping for like, 140 a tire...? i love those bfg's but they are pricey. and i have not a single clue what the best type of tire to run is. any tips?
PS: I need shocks. can i get old man emu and run just shocks, with no new coils until i can afford them? thanks
Old May 28, 2012 | 06:52 PM
  #408
Drgoodspd's Avatar
265 75 16 DURAtracs...... i have them on my 97 sr5..... eat BFGs for lunch.
Old Aug 24, 2012 | 11:29 AM
  #409
85Xtra-Cab's Avatar
Ok.. Searched for hours and can't find a matching thread to my specs. I know what my setup will be, I just need to know the backspacing I will need. Heres my specs. I'll try to make it so you don't need to ask any questions about my rig.
1994 4x4 Pickup, 22re. It has a 4" All Pro lift front and rear from what I can tell.. Still IFS.
I'm getting 4.88 gears, MT/R w/ Kevlar 33x12.50 tires, and new 15x8 black crawler wheels. I just need to know what backspacing I'll need on the 15x8's before I order them.
Thank you very much.
Old Aug 27, 2012 | 07:50 PM
  #410
StewsRunner's Avatar
is the rim size that is stated on the tire the only rim that will fit? For instance would a R16 fit on a 15" rim? Or is it just saying that 16" is best or will fit best? . .
Old Aug 28, 2012 | 05:24 AM
  #411
Badfish740's Avatar
You can't really mess with diameter. 15" tires for 15" wheels, 16" tires for 16" wheels. Sometimes you'll see 16.5" tires and some folks will try to mount them on 16" wheels since 16.5" wheels can be hard to find. They'll mount but they blow beads a lot. Wheel width is the measurement you can play with. Most tires have a range of width's they'll fit (ie: 6.5-8" or 8-10").
Old Sep 11, 2012 | 09:57 PM
  #412
jessicaisconfused's Avatar
Wheel sizes and year interchangeable?
Does anyone know if a set of stock wheels from a 1999 4runner will fit a 1996 4runner? Thank you!
Old Sep 12, 2012 | 09:37 AM
  #413
Devwon's Avatar
They will fit.
Old Sep 24, 2012 | 09:50 PM
  #414
TrikeKid's Avatar
'86 LB, all stock, 35x12.5R15 Geolandar MT's. Nipped the corner off the bottom of the front fenders and beat the firewall some, needs a little more since it still rubs some with the tire stuffed and turned to the stops. Rear rubs yes, but I'm not trimming until I get some springs that aren't sacked out in the rear, even then the trim won't be much, may even see if I can get away with just rolling them. Rear is probably down 1.5-2" from stock height at the moment.
Old Oct 8, 2012 | 11:41 AM
  #415
rattlewagon's Avatar
^ I like it!
But I may be partial to blue trucks with white rims.. Haha
Old Oct 21, 2012 | 06:52 PM
  #416
Joedarr33's Avatar
no lift. 31's. alllll dayyyy haha. im looking into getting some new 31's also. thinking about the bfg km2's ? there pretty sweet but $834 shipped. kind of expensive.
Old Oct 21, 2012 | 06:53 PM
  #417
Joedarr33's Avatar
also want something that is more smooth. my thornbirds are bumpyyyy as hellllll lol
Old Oct 22, 2012 | 03:47 PM
  #418
CitrusTheDragon's Avatar
ok I can't get a responds back from Total Chaos so I am wondering what size tire can I run on an '86 4runner TC long arm kit, 2" body lift, glassworks Ivan 3" fenders, and a t100 rear axle. width and height? I was thinking 40x14.5-16 with a 3 3/8BS
Old Nov 5, 2012 | 03:27 PM
  #419
colbyman's Avatar
i have a 1992 4runner gunna put 315 75 16 what wheels width/backspacing do i need so they wont stick out w/o fender flares
Old Nov 19, 2012 | 11:35 PM
  #420
JDM4X4's Avatar
Originally Posted by dropzone
Cut and pound
37" and no lift:
I like your style, and your truck looks great.
