Sponsored by: CARiD
No electrical power of any kind! 92' pickup
Old Jan 2, 2013 | 06:37 PM
oneuzfe8's Avatar
I am not getting any kind out of this thing. horn, lights nothing..
-good hot battery
-fuses checked
-grounding checked.
any ideas would be appreciated!
-Gillis
Old Jan 2, 2013 | 07:58 PM
rokblok's Avatar
Did you check the main fuses/fuse links under the hood near the battery? I believe the main one is an 80amp.
Or did you verify that you have good connections at the battery terminals?
Old Jan 2, 2013 | 08:21 PM
Discombobulated's Avatar
From original intro thread you mentioned it has been sitting outside for 10 years, with that said has critters got to anything?? Have you gone under over and inbetween to look for wires possibly chewed? Just a thought but worth a look see
Old Jan 3, 2013 | 01:19 PM
oneuzfe8's Avatar
Here are some photos gentlemen.
I looked and found one wire that was connected to the inner fender, next to the fuse box that was just there. Could this be my problem? Also, I double checked the fuses today. My question right now is there anyway to check the larger fuses? like the head fuse and the EFI fuse?
http://i1304.photobucket.com/albums/...ps9ed2bc7c.jpg
http://i1304.photobucket.com/albums/...ps583cb1a6.jpg
http://i1304.photobucket.com/albums/...psc5bb5cfd.jpg
http://i1304.photobucket.com/albums/...ps7ed5b706.jpg
-Gillis
Attached Thumbnails No electrical power of any kind! 92' pickup-mytruck_zps8729a902.jpg
Old Jan 3, 2013 | 03:41 PM
rokblok's Avatar
Get the cat to check the fuses...
Just kidding. If you have a voltmeter or even a test light, you can check on either side of the fuse. The big plastic square fuse may need accessed via the bottom side of the fuse block.
Old Jan 4, 2013 | 06:06 PM
oneuzfe8's Avatar
rokblok! I thinks its the main 80 amp fuse. Im going to replace it tomorrow. Thanks for the help!
-Gillis
Old Jan 4, 2013 | 08:41 PM
rokblok's Avatar
Let us know the outcome. Glad you're able to move the cat long enough to test fuses....
Old Jan 6, 2013 | 08:05 PM
oneuzfe8's Avatar
I replaced the 80 fusible link...now when I put a hot battery to the terminals... the positive post sparks and cracks like its going to blow the fuse again.....I feel like a dipward... any suggestions...
-Gillis
Old Jan 6, 2013 | 08:45 PM
rokblok's Avatar
If its minor sparks, it may just be accessories getting powered up. If its major sparks, you may have something shorted out. There are any number of possibilities. Battery cell shorted, alternator windings shorted, insulation rubbed off on a wire somewhere, etc.... Keep searching if its serious sparks...
Old Jan 6, 2013 | 10:39 PM
wyoming9's Avatar
Red face
you should always install the negative terminal on the battery last.
if the negative terminal is hooked up and you install the positive one any loads in the system will start drawing current as soon as you start to touch the battery post. The more current draw the bigger the sparks.
Old Jan 7, 2013 | 08:41 AM
Adam F's Avatar
Trace the wire going from the battery to the starter, and fuse box to alternator.
Old Jan 8, 2013 | 07:33 PM
oneuzfe8's Avatar
Thanks guys for all the help and following my thread.
My next question is does anyone know where I could get a decent vacuum line diagram for the 92' helix 2wd 22re efi..?
-Gillis
Old Jan 8, 2013 | 08:42 PM
dropzone's Avatar
Fossilized
Hilux..not helix
Old Jan 9, 2013 | 02:39 PM
oneuzfe8's Avatar
opps..
Old Jan 9, 2013 | 03:15 PM
RAD4Runner's Avatar
+1
If major, could exactly be the same thing that blew the 80-amp fuse and could do it again unless fixed.
Thick wire to fender next to Fuse block is the main body ground on first gen . connected to batt neg. probably come on yours.
Someone on forum must know typical resistance presented to battery with engine off. This is a safe way and a good place to start. Disconnect battery cables, measure resistance between pos & neg terminals of cables. IF significantly lower (meaning short) that resistance above, disconnect major components (alternator, starter solenoid, large cable to starter motor, audio power distribution cables) one at a time until you find that abnormally-low resistance disappear. Safer than experimenting and blowing fuses each time you try something that does not fix problem.
Good luck,
RAD
Old Jan 17, 2013 | 07:13 PM
oneuzfe8's Avatar
Sorry about the delay guys. Work and college are kicking my butt..
I figured out the issue with the sparks and sloved it.. it was a naked wire for the starter... im a dipward. yes I know.
My next problem is that I have no key for the blasted thing!
any suggestions on how I should handle this small problem?
In other news Ive been giving the engine bay some TLC. Hope you guys havnt forgot about me! cheers!
Gillis
Old Feb 17, 2020 | 05:05 AM
lonelyfarmer's Avatar
Key
Go to walmart and get one. It is $2.
Old Feb 17, 2020 | 11:15 AM
Co_94_PU's Avatar
They can't cut a key with out something to copy it from..
You can get the key code from the door lock cylinder and try hand filing it. Or go to the dealer and if you provide enough proof of ownership they can cut one from the key code that's linked to your Vin. Or pay the local mobile locksmith about 50 to come cut one on-site. Some are better at this than others, find out which tow company the local OD uses and then use the locksmith they have on site during auction day (watched a guy cut 12 keys in under an hour one day and he only had to start over on one vehicle)..
Old Feb 17, 2020 | 11:28 AM
2ToyGuy's Avatar
Or, you can go the dealership, I believe, and order a set to rekey the entire vehicle. Key and lock cylinders to match for the doors, ignition, tailgate, etc.
They're all actually pretty easy to replace.
Good luck, and don't lock anything!
Pat☺
Old Feb 24, 2020 | 07:06 PM
thefishguy77's Avatar
Pat☺
Any idea on the cost of this?
