Sponsored by: CARiD
NO brakes
Old Mar 28, 2016 | 04:01 PM
Vernsyota's Avatar
NO brakes
Ok Yotas yal were so much help with the electrical, lets see how you do with brake issues. After confirming the motor would run, I started on brakes BEFORE trying to drive it. The previous owner failed to tell me that he had removed a front caliper from the truck. I found this out while unloading it from the trailer. I installed a new one (rebuilt). I discovered the piston was frozen in the master cylinder. I removed the one from my 84 donor and was able to get the brakes bled but still not stopping power. I installed and new master cylinder (rebuilt). Now I can't get the brakes bled(never builds pressure). Can I expect a Looong bleed time or does it sound like something else is going on? When I bleed the brakes I don't even get spitting just barley drops. Thanks in advance. Oh, 87 Toyota 4x4
Old Mar 28, 2016 | 11:52 PM
wyoming9's Avatar
Red face
No fluid leaks in the system that pressure does not build??
air leak in the lines at the New Master Cylinder
If your bleeder valves worked fine before .
The new Master Cylinder seems to be not building pressure
Does the pedal get firm at all after pumping it a few times.
Old Mar 29, 2016 | 12:00 AM
Terrys87's Avatar
I have had a number of part store master cylinders to fail right out of the box. I would suggest getting an Aisin replacement online. You can get them for about the same price as a part store replacement. Sounds like the truck has been sitting a long time. Be prepared to just replace the hydraulic components with new stuff if it were me. I also like to take an air hose and blow all the lines out while doing brakes on a truck that has been sitting a long time.
Old Apr 5, 2016 | 05:31 PM
Vernsyota's Avatar
No brakes
I have since replaced wheel cylinders on both rear. The brake shoes are new
Replaced the rebuilt master with a new
Have to press pedal three times for brakes with engine running
I used the jar method for bleeding
I have no leaks.
Clean fluid at all four wheels.
No idea what to do.
Old Apr 5, 2016 | 11:16 PM
wyoming9's Avatar
Red face
Either you don`t have all the air out!!
Sometimes those rear brakes can take some time to get all the air out
Your rubber hoses are ballooning
Sometimes a poor connection will suck air and not leak fluid
Bad bleeders can allow air in.
Someplace either your drawing air in or still have air in the system.
The fact your pedal does get hard at least this Master Cylinder is working.
Old Apr 11, 2016 | 08:41 AM
osv's Avatar
osv
I have no leaks.
No idea what to do.
i would start by bleeding the master first, you can put a bunch of rags underneath it, and crack open/close the brake line junction at the master cylinder, until you are sure that the master is bled.
then start at the rear passenger corner, and drip-bleed until you are sure there isn't any air, cross over to the drivers side, do the same thing, etc.
Old Apr 15, 2016 | 11:26 AM
mwisham's Avatar
It is always best to bench bleed the MC before installing it. Sounds like you have a lot of air in the system.
88toyotaOleMiss
9
Mar 7, 2018 10:38 AM
Yota
11
Jul 14, 2017 08:35 AM
diabetic
Engine Swaps
11
May 28, 2017 11:57 AM
abalagtas
Jan 17, 2016 11:50 AM
farmershooter
Jan 16, 2016 11:09 PM
