Sponsored by: CARiD
Newbie Oil Change and weight?
Old Oct 23, 2009 | 10:59 PM
celticyota's Avatar
What's the longest oil filter I can use? I moving to Cheyenne with my 1989 1st Gen. So I am also wondering what weight I need to change to. I am currently in Southern California.
Old Oct 24, 2009 | 06:57 AM
93yotaSR5's Avatar
ive heard you can use tundra filters, which are longer than the 4runner/pick-up filters.
dont get fram. get a toyota, or napa gold
Old Oct 24, 2009 | 07:01 AM
pruney81's Avatar
In Wyoming it's gets pretty cold so I would just use 10W30 nothing heavier than that or you might tax the oil pump a bit
Old Oct 24, 2009 | 08:08 AM
FredTJ's Avatar
How did you come up with that and why ?
Fred
Old Oct 24, 2009 | 03:29 PM
celticyota's Avatar
thanks for the help guys
Old Oct 24, 2009 | 03:33 PM
Kiroshu's Avatar
10W30 is what toyota recommends for temps above 0 degrees F*...... and bellow like 100 degrees F* a believe.....
Old Oct 24, 2009 | 03:42 PM
pruney81's Avatar
I came up with that because when I used to have an 86 4Runner in California I ran 20W50 year round. Then, when I would drive to Montana in the winter and it would get into the teens, the oil pump would whine on cold starts because it was struggling to move the really thick oil that had been sitting all night freezing. My mechanic at the time confirmed this.
Old Oct 24, 2009 | 03:45 PM
Kiroshu's Avatar
Oil weight is based on the temp, lubrication, clearnaces, pressure, cooling...... 10W30 is about what most yotas runs because most places are average temps like 30-90 degrees year round. but if you go to a place where its always 100+ then like pruney81 said he used 20W50 in cali due to the temps.... if you live in place like alaska you will prolly use 5W30 or lower......
Old Oct 24, 2009 | 03:47 PM
pruney81's Avatar
Here in Mass I run 10W30 year round and it does fine. If, I'm not mistaken the first number in the sequence is the thickness of the oil at startup, i.e. the 10 in 10W30.
Then when it warms up it acts as a 30 weight.
Old Oct 25, 2009 | 01:09 PM
clanofcrawlers's Avatar
I'm using 5w30 in a 03 Tundra and have for the last 140K, factory recomendation and weight used in service center. Also Mobile One make a great filter as do K&N, dont know about the length.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
horunner1x
Jul 10, 2015 06:33 AM
