Sponsored by: CARiD
Newb question about leaf springs
Old Jan 24, 2011 | 12:51 PM
dhymers's Avatar
I have an 86 Toyota pickup, standard bed, 4spd manual 22R with 165k on the clock.
I've picked it to convert to electric. Much like this one:
http://www.evalbum.com/2672
I'm going to be adding roughly 12-1300lbs of batteries where the bed used to be behind the cab and under where a shorter bed will be placed.
I know I will have to beef up the leafs with either an add a leaf, or something else. (the guy above simply replaced all his leafs, I'd like to avoid that if I could...)
What is the simplest option ?
Thanks
Old Jan 24, 2011 | 01:15 PM
4Crawler's Avatar
Might try this:
- http://www.gearinstalls.com/kencoil.htm
Or a good add-a-leaf spring combination.
Old Jan 24, 2011 | 01:59 PM
dhymers's Avatar
Thanks, do you know what the capacity of the truck is stock ?
the rear AGWR is 2,500lbs so I'm assuming it will handle 1200lbs ok, but of course I have to stiffen it up a bit, would the EZ-550 or EZ-1000 be a good start ?
http://www.hellwigproducts.com/produ...elper-springs/
88sasturbotoy
Jan 30, 2026 01:57 PM
shisha1999
Sep 21, 2015 08:22 PM
priest16
15
Aug 6, 2015 07:43 AM
colasurdo
Jul 16, 2015 11:32 AM
Nickdigg
Jul 7, 2015 06:04 AM
