Sponsored by: CARiD
Newb Help. v6 and 4cyl spider gears?
Old Mar 14, 2009 | 05:04 PM
dayota's Avatar
I couldn't seem to find an answer to this anywhere. Are the spider gears interchangable from a v6 rear and a 4cyl rear. Im thinkin of welding one then having the other to switch out when needed. If they were interchangeable that would be sweet. Also are spools the same for 4cyl and v6? I no that ring and pinions def are not lol.
Thanks
Old Mar 14, 2009 | 05:32 PM
DeathCougar's Avatar
No they are not. V6 uses 4 spiders gears (aka 4pinion) 4cyl uses 2 spider gears (aka 2pinion)
Spools are not the same. THe 4Cyl are easy to weld, and it can be done without removing the spider carrier. The V6 is a little more complicated. I have not seen anyone weld that before, since it uses an enclosed carrier.
Old Mar 14, 2009 | 05:42 PM
dayota's Avatar
o ya see i wanted to weld the v6 gears. could i buy another set of v6 gears? Or is it just not worth it? Anyone do it?
Old Mar 14, 2009 | 05:52 PM
You would have to take the diff apart, and open the gear case just to get access to the spider gears. You are better off getting a 4cyl and welding it, or buying a spool.
Old Mar 14, 2009 | 05:59 PM
dayota's Avatar
I think i will go wit spool. You don't have to reset any gears or whatever to install one right? It seems to be the best route to go.
Old Mar 14, 2009 | 06:01 PM
If you do not know how to install gears, have a shop to it. You will have to set up the diff to have it done correctly. Talk to Zuk on here, i hear he is the best of the best.
Old Mar 14, 2009 | 06:10 PM
dayota's Avatar
I have the diff and it has 4.56 gears installed already so i didn't know if you had to re set gears when installin a spool or not.
Old Mar 15, 2009 | 08:02 AM
dayota's Avatar
Ooo. sry I get it now cause the spool replaces the carrier where as a lunchbox locker like powertraxx doesn't. I think i may just go with a poertraxx.
Thanks
Old Mar 15, 2009 | 08:12 AM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
Spool or lunchbox, there will be some setup required. Either way the ring gear needs to come off.
Lunchboxes are for school kids.
Old Mar 15, 2009 | 08:21 AM
dayota's Avatar
well i am a school kid that is why i prefer a lunchbox locker so i can park at school lol.
Old Mar 15, 2009 | 08:39 AM
86toylet's Avatar
Nice.
If you ever plan on going with big tires don't use a lunchbox. Get a spool, Detroit, or selectable unit.
Old Mar 15, 2009 | 09:05 AM
dayota's Avatar
I plan on running a skinny 33 (9.5 or 10.5) with my 4.56 v6 gears and wanted to lock the back. I like spool because it is predictable. I don't realy care about tire wear but i do not want to snap any axles or anything. I wheel in snow and mud a lot and some minor technical stuff. Mainly mud and snow
Old Mar 15, 2009 | 09:30 AM
86toylet's Avatar
Spools are definitly fun in the snow. I run a spool in the rear and will never go back, and I have yet to break a rear axle.
Old Mar 15, 2009 | 11:57 AM
dayota's Avatar
ya idk maybe i will. I don't need any cops pulling me over thinkin i was chirpin tires around the corner lol wit my 22re haha
Firefightersink15
Nov 23, 2015 10:32 PM
markwink
Aug 18, 2015 12:38 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Gevo
Jul 29, 2015 11:15 AM
jimtanner
May 2, 2006 08:27 AM
