Sponsored by: CARiD
need shock advice fast
Old Aug 12, 2006 | 01:07 PM
jeremystephens's Avatar
96 runner ltd
3" suspension lift
1" BL
will stock length shocks work
if not what length will i need
Old Aug 12, 2006 | 01:13 PM
Firefightertaco's Avatar
They should work for a while if u dont do any wheelin, but there gona be way to short.
Old Aug 12, 2006 | 03:20 PM
im 95% daily driver
5% off road but not too serious
Old Aug 12, 2006 | 03:23 PM
User 051420's Avatar
I see you're new here, and I'll point you in the right direction.
First, hit the search button up top and that'll help you figure out which lift you want, and how it's done.
Second, here's our fantasitc Lift FAQ..... https://www.yotatech.com/forums/f31/suspension-lift-faq-44741/
It helps to help yourself.
Old Aug 12, 2006 | 06:57 PM
i already have the lifts
3" toytec suspension
1" custom bl
i just need to know what length shocks to get
or will stockers work
Old Aug 12, 2006 | 07:46 PM
kwight's Avatar
1" custom bl
Disconnect your stock shocks. Cycle your suspension by ramping the truck on an incline or using a floor jack to find your full compression. Take a measurement of this. Next check the other side which should be at full droop. Take measurements both front and rear. When you are done, take those measurements to your off-road store and have them order the shocks that will allow that much compression/droop.
Kevin
he's gone
7
Dec 3, 2019 07:08 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
SMOD
Jul 27, 2015 01:45 PM
