Sponsored by: CARiD
My Carb Fills With Water When Filling Radiator- Why?
Old Mar 22, 2016 | 08:21 AM
SCToyotaMafia's Avatar
Why would my carb fill up with water when I fill up the radiator?
Old Mar 22, 2016 | 11:31 PM
wyoming9's Avatar
Red face
Failed intake manifold gasket or bad head gasket or a crack in the head
Allowing coolant to flow into the Carb
Coolant hose connected to the wrong place??
Old Mar 24, 2016 | 10:54 AM
Yea I thought the same but the head was just reworked. Talked to a guy I went to school with all he has dealt with his whole life said that the timing chain gets lose sometimes and rubs a hole right in the water jacket in the timing chain cover. Gonna pull that off and check it. Oh and also I permatex ALL my gaskets so I have a fail safe on the gaskets failing
Old Mar 25, 2016 | 12:13 AM
SwVa_1stGen's Avatar
Timing cover hole will allow water in the crankcase, not into the intake, your friend should of known this
You have a problem with an intake port somewhere
Old Mar 25, 2016 | 09:40 AM
dropzone's Avatar
Fossilized
Timing cover/timing chain would have been off when the head was redone, the cover and timing chain guides should have been inspected at the point.
Doubt timing chain slop is the culprit
Old Mar 26, 2016 | 02:25 PM
wyoming9's Avatar
Red face
Just because the head was done does not mean it was correct
When did the coolant in the Carb start??
Curious how this ends !!!
Old Mar 27, 2016 | 08:04 AM
Ok, I started the engine to make sure it ran we before I put the radiator and all in just let it run for around a solid minute. I threw the radiator in and filled it up. After about the second gallon of water I saw a leak from a vacuum line so I in plugged it and noticed the carb was slap full of water. So I went by process of elimination... pulled head going to recheck for cracks again, checked timing chain cover no wear holes, head gasket never even got hot enough to seal but no blow outs. Intake I looked but couldn't feel or see any cracks. IDK what else is left other then a cracked blocked... IDK
Old Mar 29, 2016 | 08:11 PM
slow-mo's Avatar
Three things to check, but I really can't imagine anyone of these causing such to occur.
The AAP (auxiliary accelerator pump) on the carburetor is controlled by vacuum switch mounted in the intake manifold. It is located in the path of the engine coolant. The two are connected via a vacuum hose. Check that no water is in this hose.
Check the large hose for the PCV vent. It is located in between the carb and the valve cover gasket. This would most likely flood the cylinders, though.
Lastly, the bottom of the intake manifold is feed with coolant. Check to make sure the gaskets are functioning. This would also most likely flood the cylinders.
Actually, one more thing I thought of, a coolant line is connected to the OVCV (outer vent control valve) of the carburetor.
parchisi
Aug 17, 2020 06:19 PM
horunner1x
May 15, 2016 11:09 AM
incendui
11
Mar 2, 2016 10:13 AM
moroza
Mar 1, 2016 10:57 PM
SueLu
Feb 24, 2016 08:23 PM
