Sponsored by: CARiD
Marlin doubler...crawler gear
Old Nov 23, 2012 | 02:33 PM
  #61
DaveS's Avatar
No change with pressure
Old Nov 23, 2012 | 03:40 PM
  #62
ThatGuy1295's Avatar
whoa! whoa! whoa! just too risky. what IF........! ya done it once when i was young and did things before my thinking process kicked in. just have a guy out side the truck or ride in the bed and try to locate the niose or come close to where the niose is to narrow it down. did you ever try a little pressure on each shifter as you drove to see if the niose changed or stopped.
I dont know seems ok. Cant be any more dangerous then being under a truck while its moving, wait a minute....
Old Nov 23, 2012 | 05:56 PM
  #63
lobukbuild's Avatar
im refering to a guy standing in a parking lot as you drive by or ride in the bed and listen for the noise. just so that im not understood. the drag a guy around on a creeper under the truck was not my idea. this is not good!
Old Nov 23, 2012 | 06:55 PM
  #64
was bein sarcastic. I wouldnt recommend the dolly thing either.
Old Nov 23, 2012 | 08:06 PM
  #65
dropzone's Avatar
Fossilized
my 4.7 case is louder than a stock 2.28 case when in low
just checked out your other thread...pretty decent truck
what are you doing for a parking brake? it is a transfer case mounted disc?
your cable actuated locker looks like a converted e locker
Old Nov 23, 2012 | 08:14 PM
  #66
lobukbuild's Avatar
ya my friends is too. but it dont sound like what he described . described a scraping sound once per revolution or so. its got me thinking of everything under his truck, just trying pin point it.
Old Nov 24, 2012 | 06:57 AM
  #67
DaveS's Avatar
Its a t case mounted disc brake.
Old Nov 24, 2012 | 04:57 PM
  #68
DaveS's Avatar
Put it in low today and it crawled just fine. Also used 4wd with the front in low and thr rear in low. Nice n slow
Old Nov 24, 2012 | 09:10 PM
  #69
paynemw's Avatar
bump!
Old Nov 24, 2012 | 10:04 PM
  #70
rokblok's Avatar
Did your noise increase in frequency? Or remain the same? Wondering if the noise sped up then it would prob trans/t-case related since they would be turning more revolutions per tire revolutions...
Old Nov 25, 2012 | 06:48 AM
  #71
lobukbuild's Avatar
does this mean you found the noise and it was the tcase brake? if so thats awesome. atleast it was nothing serious.
Old Nov 25, 2012 | 10:05 AM
  #72
DaveS's Avatar
No thats just stating it has a t case mounted disc brake. Ill elaborate more on the noise.. still havent been able to take the time to sit in the bed while someone else drives it..
At slow speeds 5-15 mph..when I go from coasting in Neutral or coasting with the clutch down and then put it in gear and let off the clutch pedal i get the metal swooshing noise right before the gear engages.
At high speeds (30+) when I take my foot off the gas and coast in Neutral or coast with the clutch pedal down it is more of a chatter. Like a bunch of BBs inside a coke can..almost sounds like a big rig when its down shifting quick.
Old Nov 25, 2012 | 03:13 PM
  #73
v_man's Avatar
I have a t-case e brake . The caliper and pad on the e brake are often loose and rub on the disk causing a noise you described . Go see if you can wiggle the little caliper or pad by hand .
It's an irritating noise to be sure . I would eliminate that as a possibility before looking elsewhere ...
Old Nov 25, 2012 | 03:35 PM
  #74
DaveS's Avatar
May be coming from the rear of the dshaft by the pinion..or so my dad thinks
Old Nov 26, 2012 | 09:36 AM
  #75
DaveS's Avatar
Messed around in my yard with the crawler gear. What all are my gear options? I started in 2wd with just the standard high for the rear case. Went to 2wd with the rear LOW..got a super slow crawl..prolly about 1mph maybe slower..I went to 4wd and left the front in high and the rear in low..still at the same speed as with just the rear in low.. Went to low low and got the same speed again. What are all my gearing options? Can I shift the tranny while using the front and rear t cases in a low range? How many different gear options do I have? NOOB
Old Nov 30, 2012 | 02:54 PM
  #76
lobukbuild's Avatar
alot and yes you can shift the tranny while in any of the tcase positions
Old Nov 30, 2012 | 06:10 PM
  #77
DaveS's Avatar
Bad videos but:
https://www.youtube.com/watch?v=PRyz...e_gdata_player
https://www.youtube.com/watch?v=0Xqg...e_gdata_player
https://www.youtube.com/watch?v=zlcD...e_gdata_player
Third video is slow speed going from N to gear...you can hear the metal sliding noise...other 2 videos are really pointless. The sound isnt accurate on them at all
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
norcal98
Aug 10, 2015 06:20 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
