Sponsored by: CARiD
K&N filter what to do with PCV
Old Mar 22, 2010 | 01:45 PM
thebrick's Avatar
To any guys running one of those chrome k&n air filter kits (20r /22r), what did you guys do with the PCV hose. Did you just put one of those little PCV air filters on it? Thanks.
Old Mar 22, 2010 | 04:24 PM
xxxtreme22r's Avatar
the pcv (rear of valve cover) should not be a part of the air filter assembly, that connection is on the carb.
Are you talking about the breather hose on the front? If so, you can put a breather filter on there although I have been having a tough time trying to find a cheap on that fits. You can also drill a hole in the bottom of the air filter base and use a rubber grommet and a plastic elbow to connect that hose to. This is how the weber air filters are.
Old Apr 10, 2010 | 03:59 PM
noizeedave's Avatar
Not trying to highjack the post, but I have a 95 with the 22re and want to put the PCV KN filter in, just curious what everyone else does with the hole where it goes in to the intake manifold? Just a simple cap?Or are people leaving it open, i know i cant fit another filter there. Or did I miss a step.
Thanks
Old Apr 11, 2010 | 05:14 PM
thebrick's Avatar
ur right, i meant the vent, not the PCV.
ladybugRC
458
Aug 21, 2020 10:41 AM
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
