Sponsored by: CARiD
intake question
Old Mar 7, 2013 | 08:39 PM
89blaster89's Avatar
intake question
hey guys i have another question, first off its a 93 2wd yota 22re 4 cylinder, im wanting to do like a clamp on filter / cold air intake setup but at the end of the intake tube theres a big metal block with a mass air flow sensor plugged into it so what will i need to do this or do i need the whole kit?
Old Mar 7, 2013 | 09:04 PM
BigBluePile's Avatar
There area lot of threads about this.....
Old Mar 8, 2013 | 05:46 AM
i searched and found nothing using the search bar
Old Mar 8, 2013 | 01:31 PM
Then you're doing it wrong........
Old Mar 8, 2013 | 01:45 PM
Teuf's Avatar
Old Mar 8, 2013 | 02:34 PM
Originally Posted by Teuf
thanks man, did you need to buy some sort of adaptor to put it on?
Old Mar 8, 2013 | 04:08 PM
Teuf's Avatar
I tig welded a mount for that filter, Stainless steel. The cone was free so I decided what the heck. PS, its more bling than anything, the stock set up is good with a stock filter. I am saving the stock box.Name:  IMG_1278_2.jpg
Old Mar 8, 2013 | 05:35 PM
cool, and by any chance do you know where the idle screw is located?
Old Mar 8, 2013 | 05:52 PM
Teuf's Avatar
There>Name:  _MG_4259.jpg
Old Mar 8, 2013 | 05:54 PM
Teuf's Avatar
On the throttle body.
Old Mar 8, 2013 | 09:01 PM
thanks man, you have been a big help, and turning in is idle up right? just like a dirtbike?
Old Mar 9, 2013 | 08:07 AM
Teuf's Avatar
The other way. In is idle down, out is idle up.. You will hear it. I have found that googleing a problem helps, it must include yotatech and the issue.. GOOGLE: (yotatech adjust idle 22re).
Old Mar 9, 2013 | 08:38 AM
ok cool thanks man
Old Mar 9, 2013 | 04:45 PM
Wierd.....
Old Mar 9, 2013 | 04:57 PM
Teuf's Avatar
Yup.
Blamalam
Mar 12, 2022 07:34 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
