Sponsored by: CARiD
Intake for my 99 4runner
Old Jan 23, 2007 | 02:11 PM
davelcarreon's Avatar
Hey guys i was wondering what was a good intake to get for my 99 4runner, ive seen the k&n one but i heard the afe one is better, i am concerned with it being not street legal, does anyone have the k&n one? anyone pleased with it?
Old Jan 23, 2007 | 03:18 PM
rimpainter.com's Avatar
What engine do you have? Assuming it's the 3.4, save yourself $200 and go with the deckplate mod and a TruFlow or Amsoil filter. Good for 5WHP right there. Search "deckplate mod" or look at the tech section for more info.
Old Jan 23, 2007 | 03:20 PM
JHRRLD's Avatar
And ISR mod; or you can get an Airraid mini intake which seems to help too. (in addition to deckplate + trueflow filter)
Old Jan 24, 2007 | 01:14 PM
CLEANSR5's Avatar
Agreed, deckplate it, you won't regret it. It's easy and it's worth every dime.
Old Jan 24, 2007 | 02:16 PM
Elton's Avatar
x2 on all the above post for what the deckplate mod and isr mod cost cant beat it
Old Jan 24, 2007 | 06:33 PM
thanks for all your replies, those all sound like good ideas, but will i have any problems when i get a smog check?
Old Jan 24, 2007 | 06:34 PM
Elton's Avatar
i dont think there should be a problem
Old Jan 24, 2007 | 06:41 PM
midiwall's Avatar
Yeah, you'll be fine.
Many of us run this stuff and there're no issues.
Old Jan 24, 2007 | 06:43 PM
BruceTS's Avatar
Not at all, it doesn't effect emissions......... I usually just put the deckplate plug in before taking it in.....
Old Jan 24, 2007 | 06:47 PM
Henrythewound's Avatar
Would getting the trueflow w/o doing the deckplate mod be silly? Also would ther be any quick mod to improve fuel economy, the 4Runner is sporty enough for me as it is (I just got a 2000).
Thx
Joe aka Wound
Old Jan 24, 2007 | 06:50 PM
Elton's Avatar
wont be silly at all trueflow filters are very good for quick mods the deckplate mod and isr mod as stated
Old Jan 24, 2007 | 07:26 PM
The easiest way to "improve" fuel economy is to go easy on the skinny pedal. Also, keep up on the regular maintenance items.
Old Jan 25, 2007 | 09:51 AM
Yes, sounds good. I guess I should have stated my initial question more clearly. Will doing the deckplate mod adversely affect fuel economy to get the exta HP boost? I currently get 15-17 mpg in town in my 2000 w/ the V6, I would love to get better mpg but don't know enough about how engines work to tell if doing these intake mods will help mpg or just boost the throttle response. I'll bet most people get worse mpg after doing these mods just because they drive more aggressively/faster due to the better pedal response.
Old Jan 25, 2007 | 10:10 AM
midiwall's Avatar
Originally Posted by Henrythewound
Will doing the deckplate mod adversely affect fuel economy to get the extra HP boost?
Ummm, yes.
In the land of particle physics and psychology, there's a concept of "youse can't get more power without burning more fuel". Well, not totally true, but since you're not compressing the fuel mixture that you have (supercharger or turbo) nor are you increasing the atomization of the fuel (injector nozzles, fuel pressure)... you're gonna have to burn more fuel to make more power.
When you do the deckplate the engine will be able to inhale deeper. That will cause the ECU to add more fuel in order to keep the the A/FR at 14.7:1. More fuel means bigger explosion which is more power.
Now, you don't have to USE the additional power that's available to you, but if you do, it'll cost you in fuel consumption.
Old Jan 25, 2007 | 12:45 PM
Thanks Midiwall, I don't think I will be doing the deckplate, probably just a Trueflow for general engine health. My 4Runner is plenty responsive for my tastes.
Old Jan 25, 2007 | 01:22 PM
midiwall's Avatar
'k.... but keep in mind that because of the "elbow" that's talked about in the deckplate mod babble, the 3.4L is starved for air. So, adding a free-flow filter (like the TrueFlow) won't help a heck of a lot unless you can get more air into the box.
Where you'll see a difference is lower in the RPM range when the engine isn't gasping for air. Once you get up higher (probably around 3000rpm) then you'll be in the starvation zone and the TrueFlow won't make a difference since there's not enough air to inhale anyway.
icentropy
Sep 16, 2020 02:47 PM
Doug4320
Mar 24, 2018 10:11 PM
BeMiceElf
Oct 10, 2015 09:40 PM
steve miller
Oct 10, 2015 01:40 AM
87blyota
Jul 10, 2015 04:31 AM
