Sponsored by: CARiD
IFS ?'s
Old Mar 5, 2006 | 05:06 PM
sc87yota's Avatar
IFS ?'s
I have a 87 xtra cab truck, arb winch bumper, 31x10.5 bfg muds. The rear sags about 2". I just ordered a pair off 3" Tuff Country add-a-leafs, to bring the rear end back up to a good level. Any ways my question is would ball joint spacers or aftermarket torsion bars(downey26mm) be a good way to lift the front of my rig?, what is the best make?, how difficult is the install?, how will it affect my ride? Thanks for the time-sc87yota
Old Mar 5, 2006 | 06:23 PM
AxleIke's Avatar
Bj spacers are mainly so you can gain a little lift, and relax the torsion bars to improve ride. Your ride is going to really be bad with the add a leafs, so i wouldn't bother.
I don't think you will want to lift the front since you'll be just reaching level with these AAL's, i would put in the AAL's and see how much lift the front needs, if any. Then decide what would be best.
Old Mar 5, 2006 | 06:40 PM
photoleif's Avatar
i've got about 1" lift in front contributed by cranked t-bars. it feels a little stiffer, but nothing really rough. i also had a rancho steering stabilizer put in at the same time, so konwing just what does what is kinda muddled. i replaced the rear springs altogether. the BJ spacers, as axleike says, would contribute a bit to your quest, but just do those if you aren't level after whatever you do.
also you could just get some extended shackles in back for a smallish lift... but that won't help your saggy leaf springs.
Old Mar 5, 2006 | 08:22 PM
lookmomnobrains's Avatar
nice thing about bj spacers is you gain a little suspension travel as well as lift.
Old Mar 5, 2006 | 10:43 PM
xxxrider's Avatar
i have noticed that ball joint spaces tend to make the spindles weak. I have broken 2 spindles before i decided to get rid of mine. Dont do the add a leaf if you are worried about the ride quality because that will make it very stiff in the rear
Old Mar 6, 2006 | 06:08 AM
AxleIke's Avatar
my spindles are fine...never had a problem either, nor have i heard of anyone else having a problem...perhaps you've got something else contributing to it?
Old Mar 6, 2006 | 03:46 PM
sc87yota's Avatar
Thanks for all of the advise guys. I'm really bummed I ordered those add-a-leafs now, maybe I will try to return them. Maybe I will just have to get new springs.
Sounds good about the BJ spacers. When installed will 33x10.5's rub at full stuff with the tire turned? Thanks again!
Old Mar 6, 2006 | 05:08 PM
tc's Avatar
tc
33x10.50's don't rub AT ALL on my '93 4Runner with NO lift (well, OK, I have +1.5" springs in the back to fix the saggy butt)
Old Mar 6, 2006 | 06:05 PM
Boaz's Avatar
really? 33's don't rub? I have a 93 P/U with 31x10.50's and the tires just slightly rub the mudflaps at a full lock turn.
Did you crank the T-bars to get the 33's to fit?
Old Mar 6, 2006 | 06:29 PM
tc's Avatar
tc
Nope - no crank, no rubbing. (no front mudflaps though)
Old Mar 6, 2006 | 07:13 PM
rocket's Avatar
remember a pickup is slightly different then a 4runner and usally requires some lift for larger tires.
sc87yota, if you return those add-a-leafs, look at these options... https://www.yotatech.com/forums/showthread.php?t=78776
Old Mar 8, 2006 | 05:50 PM
sc87yota's Avatar
thanks
Old Mar 11, 2006 | 01:11 PM
Strap22's Avatar
Sponsoring Vendor
I have never heard of any problems with ball joint spacers. You must have something else causing your problems. I have been running mine for along time and not once did they give me any trouble. I have been selling them for sometime now and have had no problems either from any of my customers.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Badlander
Oct 10, 2015 08:05 PM
dirk89
Oct 1, 2015 05:15 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
