Sponsored by: CARiD
ifs lift options....
Old Nov 25, 2012 | 04:02 PM
babyrunner's Avatar
Hello,
I have stock suspension and i just put 32x11.5x15 goodyear mtr k's on and they rub pretty bad. i already trimmed the front bumper and the back along the pinch weld and they still rub....
what should i do....
ome 2" lift back springs and front torsion bars or should i use ball joint spacers....
or just tighten up stock torsion bars.....
I went and played around and they don't rub really bad.. but i would like to be able to run chains....
thx
Old Nov 25, 2012 | 05:51 PM
racersg's Avatar
Yeah the ball joint spacers are a pretty good option. You could do the bj spacers on the front, do the Zuk mod on the rear. Maybe crank your torsion bars a bit if you still need a little more. You can search the Zuk mod and find plenty of info on it.
Good luck.
Old Nov 25, 2012 | 06:05 PM
dropzone's Avatar
Fossilized
Read those link and the included links it has
https://www.yotatech.com/forums/f116...tickys-242840/
Old Nov 25, 2012 | 06:31 PM
babyrunner's Avatar
already read all of this...
what is the best option......
simple question for all you guys...
what is the best route..
#1 ball joint spacers...
#2 ome torsion bars...
#3 just crank up stock bars...
Old Nov 25, 2012 | 06:51 PM
rokblok's Avatar
Personally, I will be doing the OME full kit for front and rear. I would use as much of the OME components that you can afford. Torsion crank would be my last option. If I had to do cheap cheap, then I would Zuk the rear, BJ spacers on the front. Seems to be the most reliable budget lift.
Old Nov 25, 2012 | 06:54 PM
dropzone's Avatar
Fossilized
Reason I posted those is that if you read them you will find your answer. This question has been answered a lot.
The options are also related to your skill set and how much you want to spend.
Cheap and don't care about ride quality crank torsion bars
Have $$$ buy ome
budget ball joint spacers
Old Nov 25, 2012 | 07:01 PM
NickMiller's Avatar
What do you plan on doing to your truck and how much lift do you want?
Old Nov 25, 2012 | 07:32 PM
BigBluePile's Avatar
SAS and 37'
Old Nov 25, 2012 | 08:08 PM
TrikeKid's Avatar
BFH on the firewall should fix your clearance problem nicely. I also trimmed the rear fender up to the next body line but my rear springs are pretty worn out. Truck had the bars turned up when I got it and it rode god awful.
Flying91
45
Apr 11, 2024 04:39 PM
89fourrunner
Feb 17, 2016 06:52 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
basfire
Aug 14, 2015 07:58 PM
coffey50
Jul 28, 2015 10:55 AM
