idle at 1500 rpm warmed up
I have a 92 4runner v6 4x4 I recently picked up. The thing drives nice but the idle is too high, around 1500 rpm warmed up. I adjusted the idle speed adjustment screw all the way down with no luck. I'd much rather try to resolve this problem on my own before taking it to a shop, any suggestions on what to try first? Thanks.
Thanks. visually all seems ok, im going to look a bit more extensively today. I've heard of the plug on the side of the throttle body, the real name has slipped my mind, getting dirty or going bad causing a very similar result. Does anyone know how to test the plug, i.e. how much resistance in ohms to be looking for? any more advise is appreciated
well to the best of my knowledge I got no resistance in the tps, so I would assume its bad, but if one were to go out in such a manner, would the high idle be the only symptom. Please forgive my lack of knowledge, I don't do much work with electronics of any kind.
Thanks again for all of the help.
Well, there are several TPS resistance tests, which one(s) were 0?
Symptoms of a bad/mis-adjusted TPS:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
If you are confident in your measurements:
- http://www.4crawler.com/4x4/CheapTri...oUseAnOhmMeter
Sounds like a bad TPS. If so, you would likely have some stored trouble codes in the ECU related to that part:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
just in case anyone has this knowledge, I called a family friend who owns a shop near-by, described my issue and asked about the tps... he found it odd to not have a c.e.l. showing, anyone have this issue with no c.e.l.?
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
