Sponsored by: CARiD
How to remove whole dash?
Old Jun 10, 2010 | 08:51 AM
rhinoliner4runner's Avatar
I am going to be replacing my whole dash with one that isnt cracked when I finish painting my interior. Anyone ever remove the whole dash? How many bolts? Where are they? What all connectors need disconnected? Please help me with this as Monday I am either buying this donor truck or am just gonna buy the dash. Any help is appreciated.
Old Jun 10, 2010 | 09:03 AM
scuba's Avatar
Huh.
Well it might help to know what year you have.
Did you check the FSM ?
http://webpages.charter.net/laydback.../9instrume.pdf
Old Jun 10, 2010 | 09:19 AM
Sorry, its an 87. And no didn't check that, but am checking it now. Thanks
Old Jun 10, 2010 | 09:38 AM
iamsuperbleeder's Avatar
I can tell you it's quite an adventure with a 91 Pickup an 87 should be just as fun
best of luck
Old Jun 12, 2010 | 06:35 PM
myyota's Avatar
Its not that hard to remove the dash, ive replaced the heater core in two 86 4Runners and the dash has to be completely removed to do it. So removing the dash it self shouldn`t take more than an hour to an hour and a half.
Old Jun 14, 2010 | 03:26 AM
OK, guys, thanks alot. I appreciate all the help from everyone. Thanks.
Old Jun 14, 2010 | 04:04 AM
xxxtreme22r's Avatar
best of luck
You were looking for that blinker fluid again weren't you?
Old Jun 14, 2010 | 04:06 AM
Yeah, what can I say. My mechanic said its resevoir is near the heater core. Lol.
Old Jun 14, 2010 | 07:28 AM
tc's Avatar
tc
It's not that hard. You'll need a philips, 10mm socket, and probably a flat screwdriver and pick.
Just look around and remove all the screws/bolts. If it doesn't come out easy, you probably missed one. You shouldn't have to pull on it too hard.
The only tricky part is the little bezel over the heater controls. You need to remove the right side first and kind of "rotate" it off, otherwise you will break it for sure.
Old Jun 15, 2010 | 05:44 PM
Thanks guys. I got all the parts I needed off I do appreciate all the help.
Old Jun 15, 2010 | 05:52 PM
craneguy001's Avatar
I got a dash cover for my rig for 80 bucks off of ebay. It stuck on with some adhesive and looks great. before it was all cracked out and faded
Old Jun 15, 2010 | 06:10 PM
PismoJoe's Avatar
Hey just an FYI, if you ever need to remove the dash pad, there is a hidden bolt behind the passenger air vent. You need to remove the air duct, and pull out the vent to access this bolt
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
PETDOC
Aug 18, 2015 05:29 AM
ViperTT
Aug 14, 2015 05:27 AM
ghostmoney
Aug 6, 2015 08:40 AM
Esibnitsud
Jul 30, 2015 08:21 PM
