Sponsored by: CARiD
How does a beadlock work?
Old Mar 29, 2007 | 07:21 PM
JulsTirn's Avatar
can someone please explain to me how beadlocks work?
Last edited by Lysmachia; Mar 29, 2007 at 07:43 PM. Reason: Changed title to be more descriptive
Old Mar 29, 2007 | 07:33 PM
MudHippy's Avatar
Beadlocks pinch the bead of the tire to the rim to help hold it in place when tire pressure is too low provide enough resistance. It is accomplished by bolting a locking ring to a rim that has a seating area where the bead of the tire rests, it's like a ring that's welded to the rim behind where the bead would normally be. The locking ring is basically a circular clamp, that grips the bead against this part of the rims.
Old Mar 29, 2007 | 07:41 PM
Lysmachia's Avatar
Pretty much what Mudhippy said. I changed your title so you;ll get more accuarate feedback Julian.
Old Mar 29, 2007 | 09:21 PM
AxleIke's Avatar
Staun also makes a bead lock that does the same thing, but is mounted inside the tire, and can best be described like an inner tube on a bicycle.
It isn't exactly the same, but it is a tube you fill with air, and it pinches the beads on both sides of the rim.
Advantages: Balances easier, is techincally "street" legal, locks both beads.
Disadvantages: Expensive, doesn't provide rim protection like a ring will, leaving rims open to easier damage.
Old Mar 29, 2007 | 10:40 PM
Elkaholic's Avatar
Originally Posted by Ric
good info. i never knew how they worked either, just i never really looked into one, but now i know
Dont know if you were bein sarcastic or not cuz of the smiley but if not that makes two of us!!!
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
