Sponsored by: CARiD
Help. Stuck on a hill
Old Apr 2, 2010 | 04:05 PM
whutface's Avatar
Hey I'm on phone phone up on a hill and truck ran fine up Here and I shut it off and now went to leave and no power when I turn the key. I checked the main batter cables and fuses and it all looked fine my aux lights still work so I have power just nothing when I turn the key
it's. 92 pickup 4x4
any help is awesome thanks
It's gonna be dark soon
Old Apr 2, 2010 | 04:12 PM
Kiroshu's Avatar
When you turn the key to the "on" postion is there light in the dash? Check ground wire on batt again. Make sure its tight and right.
Old Apr 2, 2010 | 04:15 PM
peow130's Avatar
have you tried pop-starting?
roll truck backwards in reverse.
turn key to on position
start truck.
Old Apr 2, 2010 | 04:17 PM
xxxtreme22r's Avatar
starter contacts maybe
Old Apr 2, 2010 | 04:21 PM
whutface's Avatar
When i turn the key no lights anywhere nothing happens. Checked ground why would starter kill power to everything?
I'm prettymuch just sitting here in the hail.
Old Apr 2, 2010 | 04:26 PM
Kiroshu's Avatar
If you had power everywhere before its prob a ground issue. Check that neg batt cable. What you do stall it? Sure al the fuses are good you know theres fuses under the hood and drivers side kick panel.
Old Apr 2, 2010 | 04:31 PM
whutface's Avatar
Yeah checker all fuses. And checked the ground cable. Truck was normal on the way up. Shut it off Like normal now nothing. My aux lights are wired through the pos and neg cables on the battery
Old Apr 2, 2010 | 04:37 PM
Kiroshu's Avatar
Do you have a mulitmeter with you? Its a 22re right?
Old Apr 2, 2010 | 04:41 PM
whutface's Avatar
22re no meter no tools
Old Apr 2, 2010 | 04:45 PM
Kiroshu's Avatar
You got jumper cables and another truck or car? Try hooking the cables to your truck and if theres power, theres a power issue unless your batt and alt are bad.
Old Apr 2, 2010 | 04:47 PM
whutface's Avatar
Tried jumping thanks though
Old Apr 2, 2010 | 04:49 PM
brian2sun's Avatar
Is it auto or stick?
Old Apr 2, 2010 | 04:55 PM
Kiroshu's Avatar
wow is was juat about to ask that lol is it in park or neutral in auto?
Old Apr 2, 2010 | 04:58 PM
I'm not sure but are there any fusable links on these things? I mentioned starter wasn't sure if you meant no power to turn over or no power at all.
Old Apr 2, 2010 | 05:05 PM
whutface's Avatar
It's manual trans. Heading down the hillhope truck stays safe
Old Apr 2, 2010 | 05:09 PM
bone collector's Avatar
did you make it out??
Old Apr 2, 2010 | 05:22 PM
myyota's Avatar
If you have no lights at all when you turn the key on, check the power wire from the battery to the fuse box next to the battery, that wire can corrode and go bad. I had it happen on a 4Runner once, and when i replaced that wire i had power again.
Old Apr 2, 2010 | 05:24 PM
runneroffroad's Avatar
i would try to roll start it
Old Apr 2, 2010 | 05:30 PM
whutface's Avatar
Without the engine running would I have enough braking to male it down a pretty steep hill for like 30 mins? Or would lack of vacuume boost kill me
Old Apr 2, 2010 | 05:34 PM
does your e brake work good? if soo i think u would be fine.
