Sponsored by: CARiD
Help. Stuck on a hill
Old Apr 2, 2010 | 05:47 PM
whutface's Avatar
I'm in town now and can grab a meter. Where should I start checking to narrow things down
Old Apr 2, 2010 | 05:49 PM
1989toy4wd's Avatar
I wouldnt risk it, super dangerous and you probably wont make it out alive. Brakes get hot and quit working, you also got to remember your steering column will probably lock. Call someone to pick you up. You really need a meter or something the cables may look fine, but I bet they are broken internally, happened to me one day!
Old Apr 2, 2010 | 05:50 PM
1989toy4wd's Avatar
check from the negative cable disconnected to a good body ground
Old Apr 2, 2010 | 06:09 PM
krelnydelnky's Avatar
take a screwdriver turn the key on and go under the truck and touch it to the starter positive and negative. dont touch the metal and probably wear some gloves but just link both positive and negative... should fire right up
Old Apr 2, 2010 | 06:27 PM
  #25
dropzone's Avatar
Fossilized
geez--did you even try compression starting it like people suggested? I can't count how many times I have done that and gotten home.
yes you will still have brakes if they were working prior to the truck crapping out
Old Apr 2, 2010 | 07:32 PM
  #26
whutface's Avatar
Now I think I have a tow coming paid by insurance. Thanks for the help anyway guys.
Old Apr 2, 2010 | 08:52 PM
  #27
whutface's Avatar
I'm back at the truck now local tow company got thier fancy off road tow truck up to my truck... And it broke down. So now they got another truck coming to save our trucks.
Old Apr 2, 2010 | 08:59 PM
  #28
DeathCougar's Avatar
Did you go wheeling alone, and/or without recovery gear?
I hate to turn this into a "lesson learned" type of thread, but it could be much worse. You could have been where no tow truck could get to you, ill-prepared.
Old Apr 2, 2010 | 09:56 PM
  #29
yotaman85's Avatar
as for the braking, if you have compression you have decent braking. 4low, e-brake and your foot will stop the truck. but steering is another matter..
i got a tow strap on my Chevy, dont matter where he is ill get there and pull him out.... un less he is in a 7' wide wash, then i wouldn't fit..
Old Apr 2, 2010 | 10:08 PM
  #30
881stGenRunner's Avatar
It sounds like he has a key, even if there is no power to anything, by turning the key to the ACC position the steering column is unlocked and he will be able to steer.
Old Apr 2, 2010 | 10:16 PM
  #31
yotaman85's Avatar
yea, but going down hill with brakes on and no power steering is going to be fun.
Old Apr 2, 2010 | 10:17 PM
  #32
bah, PBA (prolly be aite)
Old Apr 2, 2010 | 10:53 PM
  #33
Cascade4Byer's Avatar
the wire broke that goes from the battery to the fuse box once on my truck... thats the only advice ive got. good luck!
Old Apr 3, 2010 | 08:32 AM
  #34
whutface's Avatar
It wasn't really a wheeling trip I was going up with some friends shooting. We had one other vehicle but no I wasn't prepared for anything. Insurance paid for the tow. It was late and hailing and really windy I just wanted to get it home I've seen other trucks that have gotten stuck up there and left end up fulla bullet holes in only a couple days.
Old Apr 3, 2010 | 08:48 AM
  #35
broncrider's Avatar
^^^^^^ with and a stick shift man you point it down hill get it rolling throw it in gear. should fire up.
Old Apr 3, 2010 | 09:02 AM
  #36
whutface's Avatar
I really wasn't in a good spot to try that. The road went down hill both ways. I was lucky I was parked where I was. Also I don't understand how the ignition is gonna work if there's now power to anything?
Old Apr 3, 2010 | 10:03 AM
  #37
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Originally Posted by myyota
If you have no lights at all when you turn the key on, check the power wire from the battery to the fuse box next to the battery, that wire can corrode and go bad. I had it happen on a 4Runner once, and when i replaced that wire i had power again.
ding ding ding!
I had one with a fuse somebody put in it... It would blow them like crazy! To my knowledge you do not even put one there...
Old Apr 3, 2010 | 02:17 PM
  #38
whutface's Avatar
You guys were spot on. It was the pos cable from the battery to fuse box. Thanks!
markf1
Sep 3, 2015 01:23 AM
izzmee
Aug 17, 2015 10:20 AM
129Creepin
Aug 5, 2015 10:12 PM
Poncho0206
Jul 10, 2015 06:21 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
