Sponsored by: CARiD
help changing fuel pump
Old Nov 17, 2009 | 10:29 PM
Quagland's Avatar
I unbolted my bed and lifted it up and got to the top of the fuel tank but i can take that thing that holds the fuel pump all the way off cause there is 3 hoses connected to it that i cant get off. any suggestions?
Old Nov 17, 2009 | 11:19 PM
Elton's Avatar
looks like theres one line with a hose clamp and one line you unbolt and a electrical connection ?
Old Nov 17, 2009 | 11:23 PM
Elton's Avatar
Old Nov 20, 2009 | 06:56 AM
Quagland's Avatar
yeah thats it. how do u take the electrical part out? i dont want to break it? and the hose seems to be stuck on...
Old Nov 20, 2009 | 09:02 AM
Elton's Avatar
as for the electrical plug im sure its held in by a clip or something and for the line id hit that with some pb blaster let it soak for a little while
Old Nov 20, 2009 | 05:42 PM
Quagland's Avatar
ok, i got it done thanks =) pain in the ass but the pb blaster really helped loosing those fuel line bolts
Old Nov 21, 2009 | 10:16 AM
A_CavanaughWebb's Avatar
>.< Lol it seems you already got the problem solved, otherwise I woulda told ya to be careful around that bolted hose. It's made of metal but not real strong stuff. I broke mine by accident (I went the dropping the tank way, pain in the ass) and when I was trying to get that off, I thought I was turning the nut to unscrew it, but was actually twisting the hose. >.< I couldn't see .
Old Nov 21, 2009 | 09:49 PM
Quagland's Avatar
lol >< that sucks ehh problem still hasnt gone away... not as bad though
Old Nov 21, 2009 | 09:52 PM
Quagland's Avatar
i lost one of the bolts for my bed anyone know where i could order one?
Old Nov 21, 2009 | 10:40 PM
myyota's Avatar
what was the original problem that made you think the fuel pump was going bad ?. Did you replace the fuel filter ?, if not then it would probably be a good idea.
Old Dec 8, 2009 | 08:49 PM
ajury's Avatar
How did you get the hose off?
Im working on the same thing, currently dropping the tank (all bolts off finally) last connection is the hose pictured in this thread. How did it come off, now Im hitting myself in the head and looking into removing the bed. This has been a real pain, with many bruised knuckles!
I think I may have broke it, both sides spin now but it only turns a quarter turn then stops.
Thanks for the help, hard to work when you cant see. Cant believe I did not think of removing the bed! Thanks for the tip!
Old Dec 8, 2009 | 09:10 PM
Quagland's Avatar
did u spray it with pb blaster? thats what i did to everything lol
Old Dec 8, 2009 | 09:26 PM
DeathCougar's Avatar
Get your self a set of good quality line wrenches, and that connection will unbolt without destroying your knuckles.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
