Heli-coil problem
Heli-coil problem
1990 4Runner 22RE. I broke off a bolt that goes through the oil pump and the timing cover and into the block. I drilled it out and got the closest size of Helicoil. I am having a hard time tapping into the iron block. Also the provided tap is too short.
Any advice?
Any advice?
First off, I hope that you are using taping fluid, if not GET some, I use Tapmatic but, Tap Magic is also good, at the very least use a lot of spray lubricant.
Second, you can order standard, long, and extra-long taps from many different vendors, such as, MSC, Mcmaster-Carr, etc.
Good Luck!
P.S. I mainly work with stainless steel, hard to tap, so I use coated drill bits and taps, the above vendors sell them also.
Good Luck!
I have VERY, VERY carefully tapped the tap a couple times with a hammer in some rare instances in the past but, make sure your hole is the right diameter first, that may be the problem.
Also, you can get away with using spray lube but, a dedicated tapping fluid is best and if you are using a wrench instead of a tap handle be real careful that the tap stays straight, especially when starting out.
I've tried hammering the tap into the block a bit, and it keeps slipping out. I did some reading and wikipedia suggested using a tapered tap to cut into steal or iron. Next issue is finding the right tap that is long enough.
You're not likely to find the correct tap except from Heli-Coil. The tap is not a standard tap. It is a larger diameter to account for the thickness of the Heli-Coil insert.
I called around and, as Dave just said, Heli-Coil uses a unique sizing scheme, and it is unlikely that I can find something to work. So my options are as follows:
*have a special tap made up ($80, 2 weeks wait)
*tap a larger hole, use a wider bolt torqued to factory spec
*leave the bolt out for the time being and in two weeks deal with it when the special tap arrives
Any other options out there? Keep in mind this bolt goes through theoil pump, through the timing cover and into the block.
Matt
Matt
It wasn't a total loss though...Jay351 was quite entertained with my performance.
Jason
Matt
Matt
Also, If this bolt goes through the oil pump and timing cover then the tap will be cutting into those as well. Probably part of your problem.
Jason
or are you mistaken?
