Sponsored by: CARiD
gears or engine
Old May 2, 2008 | 11:05 AM
CAGEFIGHTER's Avatar
gears or engine
I have a 02 tacoma sr5,it has 6 inches of lift with 33" tires,would like to go to a 35"tire but it doesnt have much power now,what would be my best bet changing eng.or gears.it has a 4cyl.in it right now,also for gas mileage.
Old May 2, 2008 | 11:08 AM
CC_yota's Avatar
Gears
Old May 2, 2008 | 11:12 AM
bob200587's Avatar
....gears
Old May 2, 2008 | 11:15 AM
TOYOTA 1's Avatar
gears
Old May 2, 2008 | 11:47 AM
86Original's Avatar
Dual T-Case with stock diffs. Run 235's when not wheeling for fuel mileage. Tire weight goes up related to the square or cube of the diameter. So for every inch larger tire, your tire weight goes up quite dramatically.
In mountaineering they say that every pound on your feet takes as much effort as 5 lbs on your back. Similar is probably true for trucks & tires...
Old May 2, 2008 | 12:57 PM
tc's Avatar
tc
Wow, be glad this is in the newbie section ...
Let's see, gears will cost about $1000 ... a 3.4L V6 swap would be about $3000 ... yeah, I think gears are the cost effective way to go.
Old May 2, 2008 | 01:08 PM
DeathCougar's Avatar
Forget the gears and the 3.4l, swap in a chevy 502 and add 24" of lift! then go braffin! Yea bro!
Old May 2, 2008 | 09:15 PM
thanks for the help but money aint realy the issue,i just want the most reliable everyday driver that i can dump off in the occasional mud hole or climb a hill,but like i was saying thanks for the help
Old May 2, 2008 | 11:08 PM
hurley842002's Avatar
I would just look into some gears, with gas prices you are fine with the 4banger. The way you are now some 4.88's woud be fine but if you plan to go 35's I would consider 5.29's. Just my 2 cents.
Old May 3, 2008 | 03:11 AM
thanks thats what im going to do
Old May 3, 2008 | 08:02 PM
bigarms23's Avatar
buy a set of 488 gears front and rear and that will help
Old May 3, 2008 | 08:05 PM
crolison's Avatar
5.29's are my vote if your going 35's, for 33's 4.88's will do.
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
