Sponsored by: CARiD
gas mileage with 265/75/16 tires
Old Dec 20, 2005 | 12:58 PM
BornChaos's Avatar
im sure the answer is out there somewhere but after 30 minuets of reading, id rather just ask the queston again...
People with such experience: How much average gas mileage are you getting with 265/75/16s? did you recalibrate or gear?
please speak from experience and not theory. I have 265/75/16 and I figured (from past experience with other vehicles going up a tire size) that I would only loose around 1 mpg.. but im getting like 14 in the city and 16 on the highway and i babysit the gas pedal. thanks in advance!
Old Dec 20, 2005 | 01:00 PM
rimpainter.com's Avatar
I get 16.7 MPG on average running that size (Pirelli Scorpions); mixed driving. I am a leadfoot. Mods are in my sig.
Old Dec 20, 2005 | 01:19 PM
BornChaos's Avatar
yeah right now im getting like 14 or 15 average.. with synthetic oil (castrol syntec, 10w-30), chevron regular with techron gas... K&N air filter and just recently did injector mixture in gas (pure techron additive). i have blown CV axles but i dont have money to go 4x4 or anywhere far anyways right now.. but im wondering if blown CVs have anything to do with it..
Old Dec 20, 2005 | 01:23 PM
Define "blown CV axles."
Old Dec 20, 2005 | 01:51 PM
ebelen1's Avatar
I have 265/75/16 tires on my 3rd gen w/ stock gearing (3.73). Without recalibrating, I'm at about 13-15 mpg mostly city driving. With recalibration based on internet calculators, I'm about 10% better at 15 -17 mpg.
I have 100k miles on my truck and all service has been done. Synthetic everywhere. Only performance-type mods are K&N FIPK and magnaflow muffler. I am also pretty heavy on the gas pedal.
Old Dec 20, 2005 | 01:53 PM
Bob_98SR5's Avatar
consistently around 16-17
Old Dec 20, 2005 | 02:16 PM
BornChaos's Avatar
the inner cv boot is completely torn around and the greese is gone. right now if i do calculations based on my non-calibrated, not geared... im getting about 14 or so mpg.. maybe a little more.. so when i get my free AAA re-calibration ill be seeing like 16 city and 18 highway (which is my goal, without re-gearing). im going to do the deckplate, ISR and magnaflow 14" muffler soon too, so maybe those will get me an extra mile per gallon.
Old Dec 20, 2005 | 02:36 PM
ROOFGOOF's Avatar
Just done a highway trip...just shy of 20 mpg with my 265/75/16's.
I usually get 17 to 18mpg at best no matter how hard I drive in mixed city/hwy use.
Old Dec 20, 2005 | 03:12 PM
lee's Avatar
lee
Old Dec 21, 2005 | 12:07 AM
BornChaos's Avatar
thank you very much guys. i was kind of shocked to see how much of a loss resulted from 265/75/16 (atleast on my rig). im going to get a calibration from AAA, change my fuel filter, do the deckplate and isr mods and then see how my gas mileage is.. from theory, i assumed that it should be appropriate to loose like 1 mile per gallon for riding on 265/75/16 instead of 265/70/16 (plus the yak rack), but right now im running a bit shy.
Old Dec 21, 2005 | 05:26 AM
midiwall's Avatar
I'm getting about 15.5 on 265/75's... Remember to add the percentage back in when doing the mileage math (about 3% for you).
The deckplate will let more air into the intake, more air = more fuel, more fuel = more power. Your mileage won't go up.
The ISR mod will increase the throttle response, it won't have a direct effect on HP or fuel consumption.
If you're running a rack, you can expect a 1-2mpg drop in mileage on the highway. Around town shouldn't be too bad.
Old Dec 21, 2005 | 10:50 AM
X-AWDriver's Avatar
I'm a lead foot a bit to at least to get up to speed since I don't dawdle and with my D load range tires I get anywhere from 14-17 but it's more likely to be the 14 lately.
Old Dec 21, 2005 | 10:57 AM
Tacoma Dude's Avatar
I get anywhere from 16-19 (depending on how much freeway driving I'm doing).
I've also found that I've saved myself a pretty good amount of mileage that hasn't shown on the odometer because of the larger tire size.
Old Dec 21, 2005 | 04:44 PM
Cedarbarn's Avatar
My stock 05 highway was 21mpg (4.10 gears, 2.7 vvti motor)
With 285/75/16s I get 19 mpg highway adjusted.
I know I have a completely different motor, truck than you do, but I found that my shift points changed dramatically when I changed tire size. I have a manual so I learned what the truck liked and did not like. The first few weeks my mileage was terrible.
Do you have an automatic?
Old Dec 22, 2005 | 10:05 PM
fstdraw's Avatar
16-17.5 mpg with 265/75-16,s. '99 3.4 w/5sp. ext. cab. I take my mileage and multiply it by 1.08 that gives me back the 8% I lose with the larger tire size. So on a 200 mile fill-up(odo reading) I really have traveled 216 miles. That being said, why do the larger tires cut down on your mpg? Seems like you would get better mileage.
Old Dec 23, 2005 | 04:01 AM
99_Runner's Avatar
This is interesting and makes me wonder how much of a difference I should be factoring in with my switch from the 265/70-16 to the 265/75-16. This is on a 99 4Runner with the factory rear locker so I am pretty sure it has the 4:30 gears. Non adjusted I get 17-19, but would be interested in what the adjusted would give me.
Old Dec 23, 2005 | 05:14 AM
tc's Avatar
tc
When I went from 31x10.50 to 33x10.50, I didn't notice much of a mileage drop.
I was really concerned that my mileage dropped dramatically when it got cold - found out that tire pressure is critcial. Only a few PSI seem to make a HUGE difference! There are some posts on here about how to check to get the right pressure so the tread sits flat on the road.
shisha1999
Sep 21, 2015 08:22 PM
skoti89
Sep 11, 2015 07:46 AM
Sep 4, 2015 09:27 AM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
