Sponsored by: CARiD
Front turn signal connector, will an 89+ work on an 88?
Old Jun 21, 2014 | 08:36 AM
mct75's Avatar
Hello,
I just got an 88 2wd pickup, and both front turn signals (on the bumper) are missing. The connectors are still there, so I just need need new light assemblies. I found some that look like they would fit, but I can't find any pictures of the connector on them. My truck has a round connector that's about .75" in diameter, 2 leads. The product page says they fit 89-94 trucks only. Do they use the same connector?
Here's the product page:
http://www.amazon.com/dp/B0038B7GS2 http://www.amazon.com/dp/B0038B7GS2
Thanks
Old Jun 21, 2014 | 08:54 AM
rworegon's Avatar
From the Toyota Electronic Parts Catalog (EPC) it appears P/N 81510-89130 (right hand side) and 81520-89130 (left hand side) was used for production dates May 1984 - March 1989. What you are looking at may not work.
There is a Toyota P/N change in August 1988 so you may need to use your VIN # to properly ID what Toyota P/N you need for cross reference purposes.
See here and here. You may need to change your vehicle specs if I missed them.
And, welcome to the board!
Old Jun 21, 2014 | 09:07 AM
mct75's Avatar
Cool, thanks! I'll order those replacement assemblies.
Thanks for your welcome, I really like this board. It seems like 80%+ of all google searches end up here, so I figured this was the best board to join!
Old Jun 21, 2014 | 09:10 AM
rworegon's Avatar
Wait!! What I'm saying is the ones you want to order may not work. I don't know for certain.
One of the guys with your vintage of rig will likely chime in sometime soon.
Old Jun 21, 2014 | 09:14 AM
mct75's Avatar
Hmm, looking at that site it looks like the 81520-89130 assembly is listed for 88, 89, and 90. Those lamps on Amazon are 20-40$ cheaper than anything else I can find, so worst case I can solder an appropriate connector on there. It would fit the PO's theme for the truck nicely.
Old Jun 21, 2014 | 12:51 PM
wyoming9's Avatar
Red face
Just use any two conductor water proof plug
Unless your building a show truck.
Just please no wire nuts
Old Jun 21, 2014 | 12:56 PM
mct75's Avatar
The connector I have uses 2 recessed female spade terminals. I can hack something together with male spades and ample electrical tape. Saving 30 bucks on the lights is worth it being rednecked.
Old Jun 25, 2014 | 03:18 PM
mct75's Avatar
Well, the Amazon turn signal "assemblies" didn't come with the bulb holders so I don't have anything to work with. It's just the lens and the housing. Kinda miffed about that but I did save a solid 30 bucks that I can put to something else. Thanks again for all the help.
Old Jun 25, 2014 | 09:44 PM
Terrys87's Avatar
The lense is bigger then what you have if I recall right. They changed sizes in between those years. Just found the post. You are doing to need an 84-88.
Old Jun 26, 2014 | 09:45 AM
mct75's Avatar
This is absolutely correct. I just got them in last night, and the housing is indeed about a half inch wider than the slot in the bumper. I did some truly shameful things with zipties, and they're installed. The PO had smashed up the bumper so much that there's not a single straight line anywhere past the front wheel wells. So, it's not like I butchered a show truck.
Thanks again everyone for the help!
voiddweller
19
May 2, 2016 09:10 PM
aciorba23
Jun 29, 2015 04:18 PM
gog1968
Jun 22, 2015 05:55 AM
infinityisfive
Jun 16, 2015 06:51 PM
