Sponsored by: CARiD
formula for figuring out what gears you have
Old May 18, 2006 | 06:46 PM
BIG RON's Avatar
What is the formula for figuring out what gears you have? with out droping the 3rd members.
Old May 18, 2006 | 07:37 PM
snap-on's Avatar
its on the door pannel sticker.
if its been swaped, well you have 2 options. count the times to spin the drive shaft for 1 turn of a wheel. or vise versa
Old May 18, 2006 | 07:47 PM
BIG RON's Avatar
what if the truck was regeard.
Old May 18, 2006 | 07:49 PM
marko3xl3's Avatar
He tells you...
Have somebody you trust your life to slowly move the car, and count how many times the driveshaft spins with one revolution of the wheel.
Old May 18, 2006 | 08:01 PM
BIG RON's Avatar
:pat: :pat: did'nt see that I'v been
Old May 18, 2006 | 08:12 PM
BIG RON's Avatar
Did it, about 2 1/2 revs. in the rear and about 2 1/4 revs. in the front. Whats the gearing?
Old May 19, 2006 | 07:30 AM
eric-the-red's Avatar
That doesn't sound right, it should be around 4 - 4.5 or so. And front and rear should be the same. Instead of risking getting run over try this method. With the tranny in neutral, jack up one wheel, turn it exactly 2 revs and count the drive shaft turns. If you do the front you'll have to have it in 4wd, if you have ADD.
And if the front and rear aren't the same don't use 4wd until you get them matched.
Old May 19, 2006 | 07:48 AM
AH64ID's Avatar
The other option is similar, but doesn't require moving.
If you have a NON ADD rig you can lock one hub, have the truck in 2wd and spin the front drive shaft and see how many times it takes to get the CV to spin once.
You can also firgure it out by RPM in 4th(5spd) gear at say 50 mph, but you will have to know the rolling radius of your tire.
Old May 19, 2006 | 04:17 PM
BIG RON's Avatar
dumb question, what is (ADD)?
Old May 19, 2006 | 05:18 PM
tc's Avatar
tc
Automatic Disconnecting Differential
It's a vacuum operated solenoid that disengages the passenger side axle from the diff.
There is not really anything as "ADD hubs" - there's a splined plate that locks the hub to the CV axle constantly, so as long as the truck is moving, the front drivetrain is all spinning
Old May 19, 2006 | 08:07 PM
BIG RON's Avatar
how would I know if my front diff is (ADD) ?
Old May 19, 2006 | 08:19 PM
snap-on's Avatar
this would go a lot better if you searched a wee bit.
faceing the front of the truck look under it. if you see this big thing attached to the drivers side of the diff with wires and hoses comming from it that looks like the pic in the box that says w/ADD
well then you have ADD
Old May 19, 2006 | 08:28 PM
BIG RON's Avatar
Sorry, I was just a little confused. My truck is a solid axle. Thanks for all the help everyone
Old May 20, 2006 | 07:06 AM
AH64ID's Avatar
Well if its a SFA you can't do what I meantioned anyhow, cant see the birfields turn
BTW: What is your truck?
Old May 20, 2006 | 07:30 AM
BIG RON's Avatar
1980 toyota.....
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
razorman8669
Jul 12, 2015 12:13 PM
