Sponsored by: CARiD
FJ 80 parts, what can I use??
Old Dec 16, 2009 | 09:07 AM
PimpinUHos's Avatar
Question FJ 80 parts, what can I use??
Help. I have a 92 SR5 w/ 3.0 -- I found a wrecked 94 Cruiser and am in the process of buying the rear springs. What I'm curious about is weather I can use the LSD also, or rear axle? Or mabye one from a Taco? I can only take open diffs and 31's for so long!!! Thanks in advance.
Old Dec 16, 2009 | 09:26 AM
tc's Avatar
tc
The axles are wider. The rear has an offset diff. The rear third is bigger, but the front would work (although, it's probably a high pinion and will be weaker in a rear application)
Tie rods, rod ends, etc can be made to work and are a significant strength upgrade.
Old Dec 16, 2009 | 11:06 AM
peow130's Avatar
he could do an SAS with the front axle, but wouldnt it be a custom job?
Old Dec 16, 2009 | 03:07 PM
tc's Avatar
tc
ALL SAS's are custom jobs.
The LC axle is a great width, and if you could find a HP elocked one, you would be all ready to go, but the steering setup needs a lot of modification to work in a SAS application, and high steer is serious money, so most people shy away from them in favor of the minitruck axles.
Old Dec 17, 2009 | 08:28 AM
vandert's Avatar
Is the front axle on the correct side, I mean the pumpkin?
I just came upon a landcruiser myself and I might try to grab the axles out of it too?
Hmm, trying to get rear springs and rims off of it later today
Old Dec 17, 2009 | 01:51 PM
tc's Avatar
tc
Both the front and rear axles are passenger drop.
You will have to relocate the fuel tank to clear the driveshaft to use the rear axle.
Old Dec 17, 2009 | 01:55 PM
Ardent's Avatar
Front LC axles will also require the removal of the coil buckets and addition of spring perches for a non-linked SAS app.
Old Dec 17, 2009 | 02:24 PM
AxleIke's Avatar
Steering is hard with leaf springs on those axles, even with high steer, a bent drag link is usually required. There are a few who've made it work, much easier to link it.
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
