Sponsored by: CARiD
E-Brake Light
Old Dec 19, 2006 | 07:07 AM
4XTOYOTAX4's Avatar
E-Brake Light
My 99 Tacoma's e-brake light won't go off. I've tried pushing the handle all the way in, pushing the swith with my finger, and unplugging it all together. Anybody had this problem? What can I do short of spicing the wires together? I am tired of looking at that red light!
Old Dec 19, 2006 | 07:10 AM
Elton's Avatar
check the brake fuild level
Old Dec 19, 2006 | 07:20 AM
gpcollen1's Avatar
Ditto - Brake Fluid Level!!
Old Dec 19, 2006 | 07:29 AM
the_4runnin'_beast's Avatar
x3. Had a similar problem in my 93 4Runner. It only came on when I shifted from 2nd to 3rd and 3rd to 4th. Brake fluid was at perfect level. Replaced the brake pads and it went away... Kind of odd to me.
Old Dec 23, 2006 | 09:45 PM
notanymore's Avatar
the e-brake light isnt just a warning that your e-brake is on, its also a warning light for your regular brake system, so most likely you have a minor problem in your brake system, not your e-brake.
Old Dec 24, 2006 | 05:10 PM
TechWrench's Avatar
If it is low brake fluid in the M/C, then you should check for pad/shoe wear on all four corners. The fluid level in the M/C is calibrated so that when the pads/shoes start to wear down to the almost gone condition, the fluid level will drop low enough to trip a sensor which turns on the dash light. That's why you shouldn't 'top off' brake fluid as the level drops, otherwise the sensor might not go off, and you could be replacing a lot more that pads/shoes if they wear out.
Old Dec 24, 2006 | 05:42 PM
customcruiser's Avatar
my 94 had this problem.... would go off if i pushed the e-brake all the way in but would come back on after awhile.
the only problem that it caused me was that my cruiser would cut off when the light would come back on
i asked toyota and they said it was a common problem and easy to fix, they did it for free......... image that
i dont know what they did but you could ask the stealership
Old Dec 24, 2006 | 08:33 PM
jjrgr21's Avatar
just had that problem, check level and top off
Old Dec 24, 2006 | 08:55 PM
Twentally Misted's Avatar
I am having the same issue. It happens to me first thing in the AM. I raise the e-break and lower again and the light goes out. Im gonna check the fluid tonight! Never thought of that!
AkitaDog
Sep 1, 2015 08:05 AM
yipyip45
Aug 6, 2015 02:05 PM
priest16
15
Aug 6, 2015 07:43 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
